just bought a 86 t/a audio suggestions
Old May 26, 2012 | 02:46 PM
gmdude86's Avatar
Car: 1986 trans am ws6
just got a 86 trans am i don't want a extreme sub system just something that bumps a little maybe a bazooka tube suggestions
Old Jun 3, 2012 | 02:25 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: just bought a 86 t/a audio suggestions
Try Sonic Electronix. They have good customer service, and helped me set up an excellent system for my F-350. Rockford Fosgate Prime 150 x2 rear amp, RF speakers, an RF 300 x 1 subwoofer amp, and a Kicker shallow mount 10 inch subwoofer. Running an OEM CD6 Audiophile through a converter that they recommended allows aftermarket amps to integrate with the OE HU. The Audiophile has an 80 watt amp built in which powers the front door speakers. We also have a 12 disc Pioneer CD changer linked directly to the Satelite feed on the HU. The system functions perfectly and it thumps very well. It was complicated to set up, and the tech recalled every item without difficulty. After he got the list of items, he gave me a nice discount. It and sounds like an aftermarket system, but looks OE. They will be able to match up components for a nice aftermarket system if you want to start from scratch.
Old Jun 7, 2012 | 11:10 PM
gmdude86's Avatar
maybe ill contact them for ideas I'm a installer myself i have ideas but can always use more
Old Jun 12, 2012 | 08:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Does your 86 have the UQ7 Sound System??
Old Jun 12, 2012 | 11:41 PM
86WS6's Avatar
That's a thought. If it is a UQ7, you may want to repair/update it.
Old Jun 14, 2012 | 01:50 PM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
It's a bit on the pricey side, but I put a Kicker HS-8 in the back. It's about the size of a regular 500-1000W amplifier, and has just enough bass to make the music come alive. If you search, you'll find my thread about it, as well as my review. If you're in the mood to conserve as much space as possible, it's a great solution.
Old Jun 16, 2012 | 12:18 PM
gmdude86's Avatar
um im not sure i have the "performance" audio system but aftermarket deck the gain switch isn't hooked up and its got different front speakers then stock
Old Jun 16, 2012 | 12:19 PM
gmdude86's Avatar
ill check that out yeah i dont want blow my brains out bass I've had that already but yeah i like kicker ill check it out
Old Jun 16, 2012 | 07:52 PM
86WS6's Avatar
If you car has a gain switch, than it had Performance Sound when it was new. It sounds like the system has been scraped or bypassed sometime in the past. Often the amp or HU goes bad, and the owner updates to an aftermarket system. Performance Sound is not worth restoring unless you plan to keep the car all stock or for show purposes in the stock class. Since your car sounds like a nice driver, I would continue with aftermarket. The amplifier is a small sheet metal box located just behind the passenger kick panel, almost underneath the dash. If your amplifier is still there, and you want to sell the amp, let me know. If your car has the OE rear speakers they will be a pair of 4x6 like the OE front speakers, and a pair of 5.25 subwoofers with tiny subwoofer boxes. The whole setup is mounted in an adaptor plate that fits into the 6x9 holes. Since 6x9 speakers will fit in the rear sail panels, it opens many possibilities for an upgrade. Ian Kee at Kee Audio has a sets of custom made speakers for thirdgen upgrades, that he sells for a very reasonable price .
Old Jun 16, 2012 | 07:55 PM
86WS6's Avatar
http://keeaudio.com/fbodyspeakers.html
Old Jun 16, 2012 | 10:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
the rear boxes would look like these if you have the UQ7 sound system
Old Jun 19, 2012 | 11:09 AM
gmdude86's Avatar
ill look and see but rear speakers have been replaced i think but ill look
Old Jun 30, 2012 | 03:38 PM
gmdude86's Avatar
did you wanna buy that set up i have the uq7 rear speaker set up unfortunatley for me the actual rear speaker hole is a square bigger then the 6x9s but if you want to buy it message me
Old Jun 30, 2012 | 07:36 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
The stock 6x9 speakers were mounted to a rectangular steel bracket. I have those with the stock speakers from a 1989 Firebird.
I'm very interested in your speaker boxes as well, but being in France, shipping is going to be high, even without the four little speakers...maybe we could make a deal though...
Old Jun 30, 2012 | 07:46 PM
86WS6's Avatar
I am willing to buy the whole system if the price is right and the condition of the items are good. The only part that I am in need of at this time is the amplifier. Ian Kee is going to install new speakers and subwoofers in my OE speaker boxes, adding insulation and sealing the units as he re-assembles them. He can custom make speakers and subwoofers that are compatable with the OE system only much better than stock. I am trying to keep my car all stock, so it does not get moved into the modified class at the shows. If you want to sell the amplifier, and/or other pieces send me a PM with your price, and I will get back to you. Charles
Old Jul 6, 2012 | 07:40 PM
gmdude86's Avatar
charles i have no clue what there worth i only have the boxes and amp no speakers
Old Jul 6, 2012 | 11:45 PM
86WS6's Avatar
PM sent
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Sep 7, 2015 01:37 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
