Chrysler round face radio in a '85 camaro
Old Oct 4, 2012 | 05:10 PM
jstreiff's Avatar
Car: '85 Matrix3 Z28 Camaro
I've always hated the look of the old Pioneer tape deck radio that was in my '85 camaro and I don't have any tapes anyway. I wanted a radio that looked better, and would support aux inputs. Choices are limited to single din (looks like crap in 1.5 din opening), or double din (it can be done, but it's a hack job). Well, I had several Chrysler RBK radios, and set out to make it work. It fits in the car real nice, but I had to create a custom bezel. The following pictures are of a proof of concept bezel made of balsa wood and craft plywood, then sprayed with truck bed liner. this was my first attempt at making a bezel, but I don't think it turned out too bad, it looks a lot better than the single din Pioneer that was there.
I'm going to play with the fitment of it a little more and then maybe use it to make a mold for fiberglass or carbon fiber.
with this setup, I have several radios I can use in the future. Everything from RB1 or RB4 GPS heads to 6 disk changers (RBQ)
Attached Thumbnails Chrysler round face radio in a '85 camaro-2012-10-04_15-31   Chrysler round face radio in a '85 camaro-2012-10-04_15-33
Old Oct 4, 2012 | 09:05 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Chrysler round face radio in a '85 camaro
That looks really good! Did it mount the same as factory?
Old Oct 4, 2012 | 10:19 PM
gt4373's Avatar
Transmission: 5-Speed Manual
That Looks Pretty Good
Old Oct 4, 2012 | 10:25 PM
jstreiff's Avatar
I had to shave a little off the bottom "ears" on the radio, and knock off two pegs, drill four new wholes.... it all took about 5 mins. It also needed a antenna adaptor ($15.00)... all in all, fitting the radio in was a "piece of cake"... it was the bezel that took time.
Old Oct 5, 2012 | 08:27 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Awesome, may have to try it one day!
Old Oct 5, 2012 | 10:49 AM
jstreiff's Avatar
IMPORTANT! ensure you chassis ground the radio, the radio will work fine without it, however volume control and panal lights are somewhat unreliable
Old Oct 5, 2012 | 11:14 AM
jstreiff's Avatar
Here is the wiring for the plug. You only need speakers pins 7,8,9,10,18,19,20,21 and pin 1 (power), pin 2 (ACC), pin 3 (panel), pin 22 (ground), you can ignore all others.
The little connector is for the CD changer and is a good place to hook up AUX IN, I've got a little after market thing I picked up years ago that plugs in here and gives me two AUX inputs.
Attached Thumbnails Chrysler round face radio in a '85 camaro-chrysler-radio-wiring.gif
Old Oct 5, 2012 | 02:08 PM
JSUPreston's Avatar
With that setup, you could do one of the Chinese GPS units from autodvdgps.com. I've got one in my '03 Ram, and it's not too bad. I got mine off eBay for less than $400.
Old Oct 5, 2012 | 03:35 PM
jstreiff's Avatar
I don't have much use for GPS in the Camaro, It's not a DD, I just use it on nice days with the top down (It's a Matrix3 coach convertible) and pretty much know where I'm going. But, Yes, there is a lot of directions you can go with a somewhat modern head unit, Chrysler made a lot of differnt round face models....BTW: it sounds outstanding, I always thought the speakers were crap, it turns out the speakers are fine, it was the Pioneer POS head unit.
When using a Chrysler radio, just make sure you don't have a "CAN Bus" radio... it won't turn on without a CAN Bus signal from the ECM. From what I can tell, the round face radio's are all non-CAN Bus.
Old Nov 6, 2012 | 03:56 PM
bedbed's Avatar
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
Have seen a few of these in the classifieds lately. Anyone know how close the dimensions are to our 1.5 din? Like that it looks stockish and has the aux input.
Thanks bedbed
Attached Thumbnails Chrysler round face radio in a '85 camaro-dodge-radio.jpg
Old Nov 6, 2012 | 04:08 PM
jstreiff's Avatar
you don't want to use that one... it requires a can-bus signal to even turn on. You gotta' be real careful with newer factory radios, most are year/model specific
Old Nov 6, 2012 | 09:04 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
This one on Ebay has been modified with aux input.
http://www.ebay.com/itm/190648617532...84.m1423.l2649
Old Nov 6, 2012 | 09:27 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Thanks bedbed
this looks like the mustang radio, like 08 i think.
Old Nov 7, 2012 | 02:06 PM
jstreiff's Avatar
It's a Chrysler REF radio
Old Nov 7, 2012 | 04:37 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Pretty cool mod and these Chrysler decks sound good. However they made these in a flush-mount style. Its nearly the exact same deck. There was a guy on here that installed one.
It will sit flush and look stock in place of a 3rdgen radio. I do like your idea of taking the newer rounded out deck and modifying it to look stock. A little more refinement and it will look really good.
You can find these in late mid to late 90s/ early 2000s Chrysler cars, dodge dakotas and rams ,etc.
Old Nov 18, 2012 | 09:46 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
ewwwwwww good job but i dont like it.
Old Nov 18, 2012 | 11:36 PM
jstreiff's Avatar
It looks and sounds better than what was in there, and it's easy to change back if I ever get a decent stock style unit.
Old Nov 19, 2012 | 01:26 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Nice install, but putting something round in a mostly square interior doesn't look good IMO.
Old Nov 19, 2012 | 03:41 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
You did a nice job! It looks a lot better than a single din radio. My daughter has the same radio in a mini-van, and it sounds pretty good.
I wonder if the same type of conversion could be done with a 1.5 din Ford radio. They are square faced with a little shorter depth then an OE Delco radios. The Audiophile CD6 is Sat ready, plays MP3 format, and has a built in 80 watt amplifier.
http://replacementradios.com/product...roducts_id=822
There are some really cool Delco units that will fit in our cars with out much modification, usually just wiring adaptors.
http://replacementradios.com/product...products_id=76
Old Nov 19, 2012 | 05:55 AM
jstreiff's Avatar
I used this radio, only because I have a bunch of them sitting around the garage, and it has all the functions I was looking for (better looking than the Pioneer tape player that was in there, CD, and AUX inputs). I would not have gone out of my way to purchase one of these, just to stuff into my third gen.
You have to be careful with "modern" OEM radios because many of them require a signal from the ecm/pcm to even turn on (it seems around '04/'05 the manufacures started doing this)(research any OEM radio before you purchase one).
I will more than likely end up putting in a GM 1.5 din form factor, modified with an AUX input.... but for now this works just fine for me.
Old Nov 19, 2012 | 08:17 AM
86WS6's Avatar
It makes sense. You used what you already have, and made it look good without cutting up your car.
Old Nov 19, 2012 | 08:44 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
The bezel looks like it was made from black playdoh
you should have had a 3rd or 4th gen GM radio converted to a aux input. I picked up one super cheap on ebay
https://www.thirdgen.org/forums/car-...ry-radios.html
Old Nov 19, 2012 | 10:02 AM
jstreiff's Avatar
Well.. Like I said, I will at some point in time replace it witha GM raidio, but nothing is as cheap as what you "already have laying around doin' nothin'"".
Beside that, your ugly and your mother dresses you funny!
Old Dec 27, 2012 | 09:36 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
It looks good and those Chrysler decks are pretty good pieces, I hooked a sub to mine in a sebring and it sounded great. I might have to think about this.
Old Dec 28, 2012 | 11:32 AM
jstreiff's Avatar
I wouldn’t go out and buy one for this purpose, but if you’ve got one laying around, gathering dust, you might as well put it to use. It sounds great. The more I use it, the more I think it’ll stay for a while.
I’m going to redo the bezel at some point. This one I just knocked out using balsa wood, wood filler, and truck bed liner paint. It was a rush job for more of a proof of concept than a final product.
Old Dec 28, 2012 | 10:34 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
well I want something to replace what's in there but I absolutely hate those cheaper aftermarket decks
Posted from Thirdgen.org App for Android
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
arod231
Aug 16, 2015 02:51 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
