Need a little help in the radio area
Old Nov 12, 2012 | 10:41 AM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
Well when I got the car it had an old kenwood cd player in it that really didn't work so I was wondering since I already have a 93 camaro can I just hack out the old connector and put it in my 92 the original owner just cut wires and taped them together and I want to do it right any ideas.
Old Nov 15, 2012 | 06:09 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Need a little help in the radio area
Go to a junk yard, find a radio and pull the radio and harness (or just the harness that plugs into the radio. Re-splice the wires with the correct pigtails/harness so it will plug into the factory radio corrrectly. Then get a 4th gen Stereo from a Camaro or Firebird, get the adapter harness, plug it in and go. Only mods that you'll need to do are to enlarge the faceplate area a bit, get the adapter harness, and drill new screw holes which are hidden by the face plate. this way you'll have a CD player. Also, if you get a radio from a 2000-2002 4th gen and a GM-AUX9 adapter, you plug that into the CD changer portion of the radio and you can now run your IPOD through the adapter into the radio which is what I've done.
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
