I hate to make this my first thread (Stereo Problems)
Old Jan 10, 2013 | 08:13 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Okay, so I just recently bought an 1989 Iroc Z. I love the thing, but that's not the concern right now. When I bought it, it had a newer Pontiac Stereo with auto reversing and all that fun jazz. I bought multiple Cassette adapters because I thought they would be a cheap way to play my music and such. Alas none worked. So I bought a new stereo. As I go to pull out the Cassette Stereo I notice that it is not the original harness. I think nothing of it. I cut the wires and attach them to their designated spots on the new harness.
I started with the ground and hooked it up to the original wire, I wanted to go to power next. Of course, they say "The orange wire should go to the red wire" I was like, simple enough. Alas, I don't have any plain ORANGE wire I have an orange wire with a black stripe. I thought nothing of it. I kept on moving down the old harness cutting wires. Hooking up what I think was the accessory yellow to the designated spot on the new harness. Going through the speakers was a breeze then the new harness was all filled up. But, whats this, one wire left on the old harness. It is yellow. But that's impossible, no diagram says there are 3 yellow wires.
TL;DR
( So. I know this was a lot to read, but I have no power to my stereo in short, and I have no idea what to do.)
Old Jan 10, 2013 | 08:43 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: I hate to make this my first thread (Stereo Problems)
Here a wiring diagram for the factory radio. You can use it to wire your new radio. You wouldnt by chance have the bose system in this car? Bose system shows an orange wire in it.
Attached Thumbnails I hate to make this my first thread (Stereo Problems)-41911292.gif
Old Jan 10, 2013 | 08:46 PM
Annihilate's Avatar
Engine: 5.0
If only it was that easy. I used a wiring diagram in the first place. The orange wire doesn't exist. I have an orange wire with a black stripe.
Old Jan 10, 2013 | 08:52 PM
jermdm's Avatar
Car: 1989 Iroc-z
You might have factory bose in your car. Here is a diagram for the bose system. It has an orange wire in it.
Attached Thumbnails I hate to make this my first thread (Stereo Problems)-41911293.gif   I hate to make this my first thread (Stereo Problems)-41911294.gif
Old Jan 10, 2013 | 09:01 PM
Annihilate's Avatar
Engine: 5.0
So the Orange Black stripes is also a power source. Good to know. But if that is the case, why doesn't the Stereo have power? If this is right, everything I connected should be correct.
Old Jan 10, 2013 | 09:10 PM
jermdm's Avatar
Car: 1989 Iroc-z
Fuse might be blown for the orange/black wire. Its a constant 12v wire and should have power all the time. That fuse is located in the aux. fuse box under the dash to the right side of the steering column. Push in the tabs and it should swing down to gain access to the fuses in there.
Old Jan 10, 2013 | 09:25 PM
Annihilate's Avatar
Engine: 5.0
Alright, I will look at that tomorrow afternoon. Thank you my man, I will get back here with results.
Old Jan 10, 2013 | 09:35 PM
Guest
Guest
Posts: n/a
I know this sucks. I had the same problem. I will work on and figure out a mechanical problem all day long, but when it comes to electrical problems, I get frustrated very easily and give them the proverbial finger. For Christmas my parents payed for a new radio install, speakers, amplifier, etc. Solved my problems. Best of luck.
Old Jan 11, 2013 | 06:17 AM
DancesWithDeath's Avatar
Car: 1991 rs camaro
*sniff, sniff* a redditer.
Old Jan 11, 2013 | 07:24 AM
Annihilate's Avatar
Engine: 5.0
Pardon?
Old Jan 11, 2013 | 03:40 PM
Annihilate's Avatar
Engine: 5.0
So I figured out the problem. While looking at the fuses I found the Orange wire. Clearly tampered with. Spliced with it was the mysterious 3rd yellow wire. I looked at the old harness under the tape, the orange and black stripes was connected with the third yellow and then connected to the harness. SO, I simply repeated that, and problem solved
Thanks all!
IMissMy86TA
Aug 31, 2015 08:40 PM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
