84 Berlinetta Stereo
Old Mar 30, 2013 | 07:43 AM
BrandonMitch's Avatar
Car: 1984 Camaro Berlinetta
Engine: 5.0 305
I need help on where to find a console to install an after market stereo in my berlinetta, any help?
Old Apr 1, 2013 | 09:55 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: 84 Berlinetta Stereo
There are tons of installation kits available.
Google camaro stereo kit and have at it.
Old Apr 1, 2013 | 10:07 PM
Engine: 5.0 305
but the berlinetta have that movable stereo, do i need a whole new center console?
Old Apr 1, 2013 | 11:24 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Aaaahhhhhh, I forgot about the movable stereo in the Berlinetta. I guess we will have to wait for those in the know to answer that question. I'm now curious myself.
Old Apr 2, 2013 | 08:41 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Do a search. There is a thread here that I found when I had the same question about my '85 Berlinetta stereo.
Old Apr 3, 2013 | 09:44 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Take a look at this thread. With a little work, you can use an under-dash mounting kit turned upside down on your console.
https://www.thirdgen.org/forums/car-...head-unit.html
Old Apr 5, 2013 | 04:44 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
On my berlinetta I took the rectangle cage that came with the CD player and screwed it up under the vents. Then bent a piece of black sheet metal around the cage. slid the head unit in and it looked better then my 92 does stock. I wish I had pictures, It was a hour job from start to finish. I drilled a tiny hole for the wires just in case I wanted to run the stock deck later on.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
rusty vango
Sep 29, 2015 02:44 PM
