Any powered subs that are also amps?
Old Apr 18, 2013 | 03:52 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Right now I've got a system with a bad amp. The amp powered 2 12s in a custom board and 6x9s in the sail panels. I'd like to simplify things by just getting a 10" powered sub in a small box. But, it would also be really cool if I could run my 6x9s off of it in stereo. So basically a powered sub that is also a 2 channel amp. Does anybody make something like that?
Old Apr 18, 2013 | 04:34 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: Any powered subs that are also amps?
Yahoo search "powered 10" subwoofer car audio" but forget the part about running the 6x9's off the powered sub Not a good Idea nor does such a thing exist that I am aware of
Old Apr 18, 2013 | 04:52 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Well, it wouldn't be a bad idea if the device was designed to do it, but doing it some other way would.
Old Apr 19, 2013 | 07:01 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you can get a four ch amp and a single ten(bridge the two into one) and build a box for the ten, would be better sounding and better for the amp heat and vibration wise.
Old Apr 19, 2013 | 02:05 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
That is plan B. Plan C is to do the powered sub and run the 6x9s off the HU.
Old Apr 19, 2013 | 05:35 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
all those things would work obviously but i think plan b would sound the best and be cheaper than plan c. dont think a is possible ive never seen any powered anything that came with extra channels
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
sailtexas186548
Aug 24, 2015 10:11 PM
ZsTransAm
Aug 11, 2015 07:30 PM
