MOAR POWER - or how big an alternator can I get?
Car: 1985 Pontiac Trans Am
Engine: 305 V8 5.0L
Transmission: Hydra-Matic 4spd Automatic
So I've got a Jensen head uninstalled -
Amazon.com: Jensen VM9215BT 7 widescreen Bluetooth/multimedia system: Car Electronics Amazon.com: Jensen VM9215BT 7 widescreen Bluetooth/multimedia system: Car Electronics [1]
I've still got an alarm with remote start to add, this one: Amazon.com: Audiovox APS997C Car Prestige 2-Way Remote Start Keyless Entry and Security System Alarm: Car Electronics Amazon.com: Audiovox APS997C Car Prestige 2-Way Remote Start Keyless Entry and Security System Alarm: Car Electronics [2]
Just with the stereo, I'm noticing voltage drops a bit when I idle or I'm first backing up in the morning, to the point where the stereo has actually shut off once or twice. I'm using a brand new battery, but it's the stock rated size for the car.
I'm not sure what the amps is on the alternator, but it's a stock size, nothing super powered so at most it looks to be around 63-70, maybe less.
My research says I need a bigger alternator for my toys, so I'm wondering what you guys are using to power the tech and what will easily fit for an alternator upgrade.
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Re: MOAR POWER - or how big an alternator can I get?
I would get the electrical system tested. I am running a JL Audio 250/1 at 2ohms and measured per the instructions to put out 250watts rms at 3/4 volume (the point where my head unit distorts) Even at 3/4 volume on songs with a ton of bass, I hardly see any voltage drop. Heck, my blinkers make my volt gauge flutter more than my stereo. I nearly overloaded the car once. Had the headlights on (with large aftermarket fog lights), stereo up, and turned on the AC, that drained it and the volt gauge dropped like a rock. Turned off the AC and it was fine again.
Engine: 305 V8 5.0L
So turns out this may be related to another issue. Was doing a tune up and the timing jumped BAD, discovered the timing bolt is seized. Taking her into the shop monday, once the timing is all fixed up and the plugs are replaced, I'll see if I still get my drops when going into reverse. Hopefully this'll fix all that up.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You can get a Stock 108 Amp Alternator if you think yours isn't putting out.
Engine: 305 V8 5.0L
Nice, didn't know they made a stock one that large, should be perfect! Thanks!
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
If you have TPI,stock alternator is a 108 amp 17 si type-carb engines used smaller 12 si:94 amp for L69 and 78amp for Lg4 IIRC.All of the si types are prone to bad connection between the stator leads and the crimped on terminals that bolt to the rectifier-can be fixed by soldering.this is the usuall cause of weak SI type alternators.
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
You can grab an Ohio generator. I just installed one in a limo bus, it was rated at 200 amps but tested at 240!
They are probably the best high output alternators on the market, in my mind. They are hand wound and made to order. Great people to deal with and VERY helpful.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
There is a thread with this mod if you search.
Engine: 305 V8 5.0L
So turns out all my power problems were related to my timing. Go figure :P Got my car back from the shop today where they fixed up my timing and went ahead and did my plug change I was gonna do, and it's working like a champ now! So very happy
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
