Amp Wiring (Wire Gage)
Ok, the amp i have in requires 8 gage power wire. I'm currently using 12 gage. I know thats a big difference. What will using a smaller wire than required do?
EMAIL: CTopgun5@aol.com
_______
84' Z28
350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
_______
84' Z28
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
A thinner wire will not be able to handle as much amperage as a larger wire will. Durning high amp pulls, the resistance will heat up the wire, and you dont want that. It could possibly be a fire hazzard. Never undersize your wire.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
[This message has been edited by Justins86bird (edited September 15, 2000).]
-Justin-
Oh, wow. I'll get that changed out right away. I thought that it might just not send as much power to the amp. The wires were from my old little amp. I just left them there and hooked up the new amp. Thanx for the warrning
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
New Pioneer Sub
New Jensen 4-Channel Amp
_______
84' Z28
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
New Pioneer Sub
it will also make the amp work twice as hard to help the volts it needs to perform right which in return will make the amp get hotter
92 camaro 25th anniversarry polo green with 2 gold stripes
89 camaro
89 camaro
db057
Aug 11, 2015 10:11 PM
