amp in protection mode driving me up a frikkin wall
Old Sep 18, 2000 | 08:54 PM
myposcamaro's Avatar
my amp goes into its own little protection mode. Is there anyway i can CrAnK the volume without this p.o.s. quiting out on me? it doesnt look to good when i pull up at school and the $h!t quits out. ive tried adjusting the output level **** on the amp, but i didnt wanna turn it all the way down cuz that defeats the whole purpose of an amp, nah mean? i turned the **** to 'half, and it still hits pretty descent (for a little while, lol)
-c'mon guys, i know you know! so please reply
-kev
Old Sep 18, 2000 | 08:57 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You're obviously over-driving it. Either reduce it's load (higher impedance) or turn it down. You could try some cooling fans, but it sounds like that will be more of a band-aid than a cure.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 18, 2000 | 09:56 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Like said above, you might want to try putting a fan on it. Make sure there is plenty of air space above the amp so the heat can dissipate from the sinks. You might want to turn down the gain on the amp so your not driving it as hard. What kind of amp is it and how many speakers are hooked to each channel?
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
Old Sep 18, 2000 | 10:36 PM
BK's Avatar
BK
I sympathize with you, since my amp did the same thing. I could listen to it normally but when a good song came on and I cranked it, the thing would cut off. I had to send it back to the manufacturer to fix it. Good Luck.
Old Sep 26, 2000 | 06:08 PM
383strkr84z's Avatar
like jim said - change the impedence. I had a targa amp that was doing this once...drove me mad! I finally figured out that the amp wasn't stable at 2 ohm bridged. I change the impedence and it worked great. good luck!
jerry
84 z28 build up-
things got:
383 balanced and blue printed short block, 11 to 1 compression pistons, gear drive
,525 total lift cam, hooker comp headers ( jet hot coated), all paint needed to show, new fenders, 4 3/4 cowl induction hood, new nose, new rear bumper, 3.73 rearend (stock)
things getting soon:
preditor carb, victor jr. intake (jet hot coated), blower style air cleaner
this winter:
afr heads or vortech heads
Old Sep 26, 2000 | 11:12 PM
Topgun's Avatar
Make sure there is enough air being able to curicalate around the amp. Also, make sure you are using the right gauge wire for that type of amp. Too small of a guage will cause the amp to heat up quickly. Especilly if there is a load on it.
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Street Lethal
Aug 13, 2015 08:28 PM
Irocohio
Aug 12, 2015 08:03 AM
