Crossover install.
Old Oct 2, 2000 | 07:26 PM
Todd 92 Z's Avatar
Crossover install.
I've been getting some noise in my system after installing a X-over and I think it might be the grounds. On the outside of my X-over it has a screw hole and says GND 8 mm max. Is this another ground for the X-over? If so should I connect it to the ground wire or what? Thanks.
Old Oct 2, 2000 | 09:27 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Should be no harm in trying. I believe its meant to be an extra ground if you have problems. Just make sure to hook it up near or on top of the nearest amp or radio ground. I don't know where u have things situated but ground them together if possible
gixxer92
May 18, 2017 11:20 AM
Thaney9
Oct 24, 2015 07:26 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
gta892000
Sep 16, 2015 12:40 AM
formula_novice
Aug 18, 2015 08:48 PM
