Radio reception poor.
Old Sep 24, 2000 | 07:52 PM
Chuck's Avatar
I like my stock Delco radio in my '89 RS.
The radio reception is just not very good
compared to other cars I have.
Would an amp help? Or other ideas???
Thanks!
Chuck
Old Sep 24, 2000 | 08:38 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
First off, make sure your getting a good connection between the antenna and the radio. Maybe the plug on the back of the radio is lose, or there is a partial break in the cable. If everything is ok, there are antenna signal boosters you can buy. Don't know how well the work tho.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Sep 25, 2000 | 04:18 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Ant. boosters work okay as long as your antenna cable and antenna are in decent shape.But sometimes you'll get interference because it will pick up close-by stations from cities or towns that share the same frequency as your local station. It will pick them up very weakly, but just enough to cause static and annoy you.But this is not too common of a problem, but it can and does occur in certain places. they do pick up stations pretty good and clear up static. But first make sure all your connections are good and you cable is okay.
Old Sep 25, 2000 | 07:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I agree with Justin. 2/3 of my thirdgens have had bad antennas, and on my way to work today my last one seemed to pick up absolutely nothing (although it was fine on saturday???). Replacing the antenna is somewhat time consuming, but pretty easy (unless it's a power antenna). They are also really cheap.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 25, 2000 | 08:37 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
My car has always had crappy reception compared to any other car. I tried a $20 Antenna booster from Radio Shack, and it did nothing!! I just listen to a lotta CD's
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic/AT/T-tops/all power
Hypertech chip/2 K&N filters/Modded air box
Eclipse CD/Eclipse 100x4 amp/Boston4x6 plates, 6x9 RX 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Sep 26, 2000 | 05:15 PM
AtomicWart's Avatar
Buy a better antenna. I had a crappy one on my car 'til it got stolen. So I bought a new one at autozone, it amazed me at the difference in reception. Just a suggestion.
Old Oct 5, 2000 | 05:16 PM
Eggplant Jeff's Avatar
I also get significantly worse reception in my Camaro than in my wife's car. I might try a new antenna... What about the antenna cable? Does that go bad often, or is it just part of the antenna when you buy a new one?
And what about dual antennas? Would that help?
Old Oct 5, 2000 | 08:02 PM
Jim85IROC's Avatar
The antenna comes with the cable, and unless your radio is set up for dual antennas, you will not benefit from two, in fact it will likely hurt the reception.
The IROC Homepage
Old Dec 5, 2002 | 10:12 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
ok, where would i buy an antenna online that would look like the stock one? my stereo has some static now and by replacing the antenna would fix this?
thanks
bub
Old Dec 5, 2002 | 05:08 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
you can pick up new ones from just about anywhere, from autozone to wal-mart. good luck.
Old Dec 11, 2002 | 09:30 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
replacing the antenna is good, but it sucks replacing the mast.
the idiot that had my car before me cut the antenna wire and wrapped it around the stock radio antenna. with an antenna adapter, some soder and electrical tape i was able to repair it untill i got the guts to take off my 1/4 panel to replace the mast.
Old Dec 11, 2002 | 01:58 PM
bubbakutz's Avatar
Engine: LG4
ok....i really dont know anything on this subject....what is the mast? i have to take off my 1/4 panel to replace the antenna? can i just get a new antenna and use the old antenna wire or will the reception be crappy still?
Old Dec 11, 2002 | 02:32 PM
HamSpiced's Avatar
heh, no, to replace the antenna you just unscrew the old one and screw the new one on.
the antenna mast is the base that bolts onto the car and then teh antenna screws onto that.
Old Dec 11, 2002 | 02:47 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
My radio in my 89 GTA would only pick up one radio station most of the time. I checked the antenna and cable and all was good. I replaced the radio with a new CD player and that took care of it.
Brian
Old Dec 11, 2002 | 02:51 PM
bubbakutz's Avatar
Engine: LG4
well the stock radio did not pick up anything at all.....i just recently replaced it with a new alpine......it picks stuff up be its a little fuzzy
Old Dec 11, 2002 | 03:13 PM
bubbakutz's Avatar
Engine: LG4
to replace the antenna is all i need to do is replace this? it seems like replacing this would do nothing.....would a new gm one do the trick?
Old Dec 13, 2002 | 04:48 PM
bubbakutz's Avatar
Engine: LG4
anyone?
Old Dec 13, 2002 | 07:11 PM
HamSpiced's Avatar
yea.. just get a new antenna. if that doesnt work replace the mast. and if that dont new headunit...
Old Dec 13, 2002 | 09:07 PM
bubbakutz's Avatar
Engine: LG4
ok, ill try a new antenna......hope i dont have to change the mast cuz that looks like it would be a pain in the ****........the headunit is brand new
Old Dec 16, 2002 | 10:23 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
My power antenna no longer works (hasn't work since I bought the car...it's limp). You can move it up and down by hand. Could I replace it with a non-power mast? What's my options?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
