Hearing somebodys stereo from blocks away
Old Dec 18, 2001 | 07:02 PM
87transam5.7tpi's Avatar
Does anybody know what kinda watts or DB's it takes so people can hear you from like 2-3 blocks away? I wanna be able to beat my friends(theres only goes about a block) and I'm gonna run a 12" infinity reference with 225w will this beat them? Thanks for the time.
Old Dec 18, 2001 | 07:57 PM
camaro6spd's Avatar
you can say goodbye to you equipment....if you play it loud you do not only get your friends attention you get the audio theves attention real good....no i think it might take 2 but i could be wrong.....2-3 blocks is along way with background noise.
Old Dec 18, 2001 | 09:55 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you will blow your low end infinity sub if you turn it up that loud. you would need at least 2 so you could split the power between the 2, that way you avoid blowing the driver of the sub.
Old Dec 18, 2001 | 10:52 PM
deadtrend1's Avatar
personally, i used to have the back window of my truck flexin, and my amps had the power to be loud, but my alternator didnt And you could hear it down the street from my house which was a few blocks. The amps were a soundstream 80x2 amp, and a 120 watt x 2 pioneer amp pushing 2 12" rockford XLC's.
now i got a kicker zr240 amp and dual 12 in Jl W0's and i can hit over 140 decibles with that and thats a lot louder than my truck.
so in short, didnt take wattage for me, more along the design and placement of the subs.
Old Dec 18, 2001 | 11:00 PM
91 z28 350's Avatar
Car: 91 Z28
buy the new mtx 15 inch subwoofer i think its the rl15 or something it can handle 4000 or 3000 watts i forget what 1 it costs $1000 and u'll probally need a bunch of amps but u'll be heard from probally 10 block and u'll probally go def at the same time
Old Dec 18, 2001 | 11:05 PM
Ha ha! thanks for the advice with that MTX. I'd do it if I had the money but I don't so....... I'll stick with my infinity.
Old Dec 18, 2001 | 11:45 PM
Mike92RS's Avatar
I'd do it if I had the money...
I wouldn't...you can't even play real music on it can you? If you want a massive SPL sub there are other options such as the IDMAX, or even the tried-and-true HCCA's, which are also superb SQ subs.
- Mike
Old Dec 20, 2001 | 03:44 PM
383 Smoka's Avatar
4 15 inch Rockford Power DVC's!
I have 4 15 inch Rockford Power DVC's @ 2000 max, 1000 rms.. Running them are 4 Rockford BD1000a1's... This setup can be heard from miles away!!!! Well not that far, but farther than most.... I can turn it up even close to full when im in the car because it takes your air away... Cant even breathe.. I am very happy with it, and if u want to beat your friends? YOU WOULD KILL THEM WITH THIS!
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
greenyone
Sep 8, 2015 08:41 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
