Vented or Ported?
Old Dec 21, 2001 | 11:09 PM
killer305's Avatar
Vented or Ported?
what you you guys choose in a custom box for 2 12's. both have 200watts going to them.
THanks
Old Dec 21, 2001 | 11:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Vented or ported is like asking if you have an engine or a motor. Same thing dude.
Old Dec 22, 2001 | 10:37 AM
killer305's Avatar
alright thanks, i just didnt know if one sounded better then the other
Old Dec 23, 2001 | 12:38 AM
TrueBlue91RS's Avatar
Do you mean ported or sealed?
Old Dec 23, 2001 | 10:16 AM
jobryan26's Avatar
Yep I like a Sealed enclosure waaay better than any of the others.
Old Dec 23, 2001 | 10:49 AM
killer305's Avatar
opps didnt even notice i said that till know, yeah i mean ported or sealed tghanks
Old Dec 23, 2001 | 12:46 PM
Depends on which subs you're going to be running. Usually the manufacturer has a suggested box type and, if you're lucky, even has the performance specs of their sub in various box configurations.
Generally speaking though, sealed enclosures are much smaller, easier to build, more forgiving if box volume is slightly off, and provide more sound quality.
Vented/ported enclosures attempt to maximize the SPL (loudness) of the sub. They usually require a larger enclosure size and can be finicky to tune properly. Remember, a port is not just a hole with a tube, it has to be a precise diameter and length in order to perform well. However, when it's done right a vented enclosure can sound very good and does put out more volume at equal power levels compared to sealed boxes.
Hope this helps.
Old Dec 23, 2001 | 12:53 PM
Actually, after looking at your original post again, it looks like a sealed box may be your only option. Two twelves in a ported box will most likely be very difficult to fit in your trunk well. So, if you're dead set on two 12's, then look for pair that is optimized for sealed enclosures. Also, using a dual chambered box would be ideal for this configuration.
Old Dec 23, 2001 | 12:55 PM
killer305's Avatar
thanks, i was thinking sealed anyway
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Fanatic1074
Oct 2, 2015 03:47 PM
bplessy
Sep 30, 2015 12:14 PM
