Amp trouble
Old Dec 30, 2001 | 09:00 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Amp trouble
Recently I got some CV componants and hooked up a 2nd amp to run them off of. I was told
to run lines from the Power, antenna, and ground to the 2nd amp, and it should work. Well the power light came on, on the 2nd amp, but no sound from the speakers, what am I doing wrong?
Old Dec 30, 2001 | 09:07 PM
jobryan26's Avatar
Re: Amp trouble
Antenna??? Did you run another set of patch cables? You didn't mention that so I have to assume that you didn't.
Old Dec 30, 2001 | 11:49 PM
MotoGod's Avatar
If your gonna run 2 amps I suggest you invest in getting some distribution blocks for power and ground. They are generally pretty cheap (under $30 each for middle of the road ones) and add a bit of style and performance to the system.
You'll only need one power wire from the battery....and one ground to the chassis. From there you can hook up as many amps as you have distros on the block.
You still need to run a set of RCA's for each amp though...unless one of your amps has a pass through connector...then you can simple daisy chain them together without too much signal loss. I've got 2 Rockford Fosgate amps installed...and the one I am running in 4 channel mode utilizes the pass through. My 2-channel doesn't.
Old Dec 31, 2001 | 12:22 AM
87transam5.7tpi's Avatar
first off I agree with jobryan did you hook up rca cables? if you did make sure your speaker connections have good conections also.
Old Dec 31, 2001 | 10:33 AM
BuddyLeeX's Avatar
damn...i forgot about those hah, do I have to run another RCA from the deck to my new amp?
Old Dec 31, 2001 | 10:35 AM
jobryan26's Avatar
Yep.lol
Old Dec 31, 2001 | 12:30 PM
if the amp that you have now has rca outs you can just plug into those puppies and save alot time and work!!
Old Dec 31, 2001 | 04:05 PM
BuddyLeeX's Avatar
yeah tey do, and tahts what i did, but i think the amp im trying to hook em up to is a piece of crap, ir still wont work
Old Dec 31, 2001 | 04:06 PM
MotoGod's Avatar
What kind of amp is it?
Old Dec 31, 2001 | 04:22 PM
jobryan26's Avatar
Double check your RCA's and your Speaker Wires. What color is the light on the amp? Have you tried unhooking the RCA's from the Jenson connecting them to the new amp?
Old Jan 1, 2002 | 12:39 PM
BuddyLeeX's Avatar
yeah i tried that, and they wont work, i think the amp is fried or some ****, the power light come son
Old Jan 1, 2002 | 12:53 PM
jobryan26's Avatar
So you tried swapping the RCA's and it didn't help. You said the power light come on but you didn't say what color the power light was or what amp this is. What amp is it?
Old Jan 1, 2002 | 02:06 PM
BuddyLeeX's Avatar
the light was red and its a "T-sonic" I think its really old. Its says its a 125w+125w, so Im guessing its a bridgible 250w amp?
Old Jan 1, 2002 | 02:23 PM
jobryan26's Avatar
Cool now we're getting somewhere. The light being red means it's in protection mode so your amp maybe ok and there's just some problems in the wiring. Also make sure you are using the proper gauge wire. Like 8 gauge or larger for the Power and Ground.
These are the wires that need to be hooked up on the amp:
+12v - runs to the battery
Remote - it turns the amp on and off VIA the keyed ignition
Ground - This maybe the problem so check this one and make sure the Ground wire is connected to "BARE METAL". If there is paint or etc. between the wire and the metal then you won't get a good ground therefore causing the amp to give the Red light(protect mode). The shorter the length of the ground wire the better.
Input L&R - this is where the RCA's connect
Speaker Outputs L&R - These run to the speakers
Yeh check that ground wire.
Old Jan 1, 2002 | 02:41 PM
BuddyLeeX's Avatar
whoa whoa, i have the smaller amp hooked up to the jenson, there are 3 lines running from the smaller amp to the jensons power, remote and ground? Is that ok....and....haah...Im using speaker wire to connect them...lol i think that is the biggest problem, i didnt ko wu had to use 8 gauge wire lol. Is that it?
Old Jan 1, 2002 | 03:38 PM
jobryan26's Avatar
I think you might have found the problem The problems your having alone can be from just the fact of running the second amp off of the Jenson. But then add the fact of the very small (probably 16gauge) wire would make the problem an even a bigger one. You need to buy a distribusion block and some 8gauge power and ground cables That should hopfully fix your problem. Let me know how it goes. John
Here's you a pic I threw together to show you how to properly run the Power and Ground Cables. The Ground cables that run from the Amps are grounded to the Body by drilling holes and sanding around the holes to remove the paint.
Old Jan 1, 2002 | 05:34 PM
BuddyLeeX's Avatar
ok thanks, how much do distribution blocks cost?
Old Jan 1, 2002 | 05:42 PM
jobryan26's Avatar
You can buy them for around $20.00 up at your local Stereo Shop. You can get them with or without fuse holders. With fuse holders it's gonna cost more.
Old Jan 1, 2002 | 11:17 PM
MotoGod's Avatar
Distribution blocks are pretty cheap. If this is just for personal use (no shows or stuff like that), then you can get by with a cheap distro block. Pick up 2 of em (if you can afford it!)...1 for power....1 for ground.
Makes life VERY easy when you wire (or re-wire) the system. Plus it aids in trouble shooting. I would definately go for a fused distribution block...again if you can afford it!
I've got 1 or 2 old ones kicking around here....so if you have trouble finding them....or they are too much $$$ let me know. I'd send ya these for shipping charges ;-)
I don't really have a need for em....but I would have to dig em up!
Old Jan 2, 2002 | 11:09 PM
make sure you didn't blow your fuse too. I blew mine without even knowing it. It took me 10 minutes to figure that out. DUH! :-)
Old Jan 3, 2002 | 02:15 AM
Mike92RS's Avatar
It could be your speaker wire too. Try hooking your other speakers up to the amp (move them from the Jensen to the amp that doesn't work, just to see if you can get sound).
- Mike
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
