Wiring a manual switch onto an amp.... ?
Old Jan 10, 2001 | 01:31 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Ok,
I want to install my amp with a cutoff switch on the console. Would I wire the switch onto the + wire, the ground, or the power antenna wire (that I assume can be used to tell the thing to turn on)?
I want to be able to shut it off while Im driving, incase I have to go into a store or something, I dont want everyone in the parking lot knowing what is in my hatch!
Thanks for the help,
Any suggestions for wiring an amp into the car would be helpful, as I am doing the install in about a week!
Thanks,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Jan 10, 2001 | 01:40 AM
TAMECH's Avatar
If you want to wire up a switch, put a toggle switch in between head unit and amp on the remote wire (more than likely a blue wire from your deck that you will be connecting to the remote wire on your rca cables.) Or turn the main volume down a block (or a mile depending on stereo) before you get to a store.
1987 T.A.
4 bolt 40 over MSD 6al BBK/EDL throttle body Accel coil, wires Compu Cam Roller roc K&N filter Jet custom chip Removed screens and cooling fins on M.A.F. Ported Corvette heads 700r4 shift kit 40+ 4th gear 2300 stall Stock GTA rims with 255/50/16 rear 245/50/16 front Z rated comp ta's
Old Jan 10, 2001 | 08:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Does your radio have a volume control?
Now that I'm done giving you a hard time, I'd basically suggest just what Kiztope said. Just wire the switch into the remote lead.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 10, 2001 | 10:10 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks,
Should I put a fuse or anything in line before the switch?
Old Jan 10, 2001 | 12:38 PM
Jim85IROC's Avatar
It wouldn't hurt. Use a .5 amp fuse.
The IROC Homepage
Old Jan 15, 2001 | 08:22 PM
camaroguy99's Avatar
One thing I noticed. Don't use your power antenna lead. Then if you want to play a cd (or a tape depending) then the amps won't turn on. As for the fuse it's a good idea but I think most already have fuses on them.
Old Jan 15, 2001 | 09:57 PM
Jim85IROC's Avatar
hehe. Camaro Guy is right. We just had this problem at work the other day. Some decks just have a single blue lead that works for the power antenna and the remote turn on, but some newer decks like the Alpines are providing separate wires for the antenna and the remote lead, and an antenna wire will not have power when the cd player is on.
The IROC Homepage
Old Jan 15, 2001 | 11:09 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Hmmm, I never thought of that.. talk about not looking ahead!
Thanks, it looks like I'll have to figure out another wire to wire it to. I dont believe that my deck has that other wire on it.
Thanks again,
Daniel
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
89GTAOz
May 16, 2020 09:31 AM
fasteddi
Sep 2, 2015 10:29 AM
355sbcTPI
Aug 19, 2015 04:38 PM
