85 antenna problems
Old Oct 9, 2017 | 09:32 AM
jim iroc-z's Avatar
Car: 85 IROC-Z
85 antenna problems
I have a Kenwood radio installed. My power antenna will go up when radio is turned on but will not go down when I remove the face plate. any ideas?
Old Oct 10, 2017 | 06:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 85 antenna problems
Does the antenna go down when you turn the radio off ?
Old Oct 11, 2017 | 07:55 AM
jim iroc-z's Avatar
Car: 85 IROC-Z
No
Old Oct 11, 2017 | 04:52 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So if it doesn't go down with the face plate removed, or the radio off with the face plate on, when does it go down? Just with ignition off?
Old Oct 12, 2017 | 02:50 AM
jim iroc-z's Avatar
Car: 85 IROC-Z
I have to push it down by hand.
Old Oct 12, 2017 | 04:48 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
was your antenna working beforehand? did you use the solid blue one or the blue one with the white stripe?
Old Oct 12, 2017 | 07:54 AM
jim iroc-z's Avatar
Car: 85 IROC-Z
bought the car a month ago with the Kenwood installed and it has never worked correctly
don't know
Old Oct 12, 2017 | 07:58 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
I would check the wiring. it's possible they swapped the remote turn on wire and power antenna. My stereo has 2 blue wires. One for amp and one for the power antenna.
