Remote turn on wire,how many on one wire?
Old Jan 27, 2001 | 09:50 AM
Todd 92 Z's Avatar
I'm rewiring all of my system (doing it right this time) with high quality wire etc. and I have 3 amps and 1 electronic crossover. Can I wire all of the remote turn on leads together to the single deck wire without straining the deck? Or would adding a relay to power them be a better idea? Thanks!
Old Jan 27, 2001 | 11:22 AM
T/A Man's Avatar
The answer to that question is maybe, but I wouldnt do it. I am a former a car audio installer of 3 years and your question is very commonly asked. The average amperage output that the internal relay inside your head unit that controls the amp turn on/off is about .5 amps. This is fine for turning on 2 to 3 devices.
Since I have myself have damaged a brand new Kenwood CD player wiring 2 amps, x-over, Para-eq. Granted that was 6 years ago and CD decks are probably made a lot better now and if the deck is a high end model, it probably has a beefier relay built in for multiple amps. But its better to be safe than sorry.
I would install a Bosch relay. You can get them at Radio Shack for $4.00.
Old Jan 30, 2001 | 01:04 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Most manuals will list the max amps out for the rem. wire. Test each component you want to use with a DMM and measure the current draw. Add up all the amps and if it close to or above specs, you'll have to relay it.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 30, 2001 | 04:14 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I have an active cross over and two amps and I think that I should add a relay. It would be for the best.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Derick15
Sep 17, 2016 05:28 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
