Cassette ejecting
Old Jan 12, 2018 | 11:57 AM
Jayess's Avatar
Car: 67 GTO & 85 T/A & 2010 Vette
Engine: 400 CID 4 bbl & 5.0 TPI
Transmission: Turbo 400 & 4 Speed Auto
Cassette ejecting
I have an original 85 T/A with the upgraded radio with the graphic eq, and stereo cassette. The radio works fine, but, when I put in a cassette, it ejects immediately....any thoughts would be appreciated!
Old Jan 12, 2018 | 12:33 PM
Drew's Avatar
Re: Cassette ejecting
You need to replace the drive belts. /thread
Old Jan 14, 2018 | 03:41 PM
Doc1991's Avatar
Is there a thread or video that shows how to do that? I have a 91 Z28, and the original radio did the same thing. When I inserted a cassette tape, the tape would automatically swap from side A to side B back to side A and then automatically eject.
Old Jan 14, 2018 | 03:54 PM
Drew's Avatar
Google for some combination of Delco Cassette drive belt blaupunkt eject. Several step by step tutorials and sources for the belts.
The short version is that GM used the same cassette radio in many applications, and when the rubber belts dry out and crack like the O-ring in your GIJoes or an old rubber band, the cassette unit will spit the tape back out without playing, with or without auto-reversing a few times first. It's a very common failure mode, a known issue with a known fix that's been documented for 20+ years. Probably a Youtube video or two out there, if a person looks long enough.
It's so common there should really be a sticky or tech article about it.
Old Jan 14, 2018 | 04:47 PM
Jayess's Avatar
Thanks for the responses!!
Old Feb 1, 2018 | 08:59 PM
TA8487's Avatar
Car: 1987 GTA & 1984 Trans Am
Engine: 383 stroker TPI
I have a couple spare cassettes that I tested recently. It is simple to swap the mechanism. A couple screws and unsnap the cable and then reverse the process.
SIMON HOLTBY
Car Audio
Aug 14, 2011 01:20 PM
Larry Dunlap
Car Audio
Jan 5, 2002 10:32 PM
RED92
Car Audio
Jul 31, 2001 01:41 PM
Bob M
Car Audio
Oct 17, 2000 11:27 PM
