Cassette to CD swap
Old Jul 25, 2001 | 08:14 PM
RED92's Avatar
Cassette to CD swap
I have a 92' Camaro, and am replacing the factory non-bose cassette stereo w/ the factory non-bose CD stereo. Does any one know if I can use the same wiring harness, or if I will need an adapter or redo the wiring?
Thanks...Alex
Old Jul 25, 2001 | 08:28 PM
crumblinghevens's Avatar
Actually, I just did that today. Got one out of a 97 transport. I have a 90 Formula, and the wiring is the same, but my power antenna won't go up for some damn reason. It will fit in the dash, but the brackets don't line up. I bent them back, and pushed the deck back further. Looks like it came that way. Good luck!
Old Jul 25, 2001 | 09:47 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Alex,
I just received my non bose factory cd player today and compared it to my non bose cassette player.
Everything is the same in back but the cd player has an extra set of inputs (7 spaces with 5 pins) while my factory cassette player did not have any???
What are these extra pins used for?
Alex and crumblinghevens, did your factory cd players come with the extra set of pins?
My cassette had 4 sets of inputs (2 with 4 pins and the other 2 with 6 pins).
If this extra set is not used, what is it for? My camaro diagram shows only lists 14 wires for the 92 camaro radio.
Any help would be greatly appreciated.
Manny
92 Bright Red z28, 350, 47k miles, pw, pl, power mirrors, power drivers seat, rear defroster, limited slip performance axle, 4 wheel discs, red leather interior and the Heritage Package!!
Old Jul 25, 2001 | 10:42 PM
u r sofa king we tah did's Avatar
cd changer maybe? or steering wheel controls?
Old Jul 26, 2001 | 02:52 AM
cd-changer or steering wheel controls...maybe. It could be why my power antenna won't go up? That doesn't make sense though, because my factory cassette used the same harness and sent the signal when the deck came on. Right now I'm installing a generic alarm(enough to keep the ametuers[spelling]away), and also a toggle for the antenna. My deck might be different. let me describe: It uses the same harness so it plugs in, turns on, and plays music. BUT, there are extra pins not used in the same location. There is also the extra set of pins(picture looking at the back of the deck)in the center. And the antenna plug. Diagram---
|--0----| ------ |---------------|---------|
Ant. extra what plugs in
Not sure how this comes up but I hope it helps. My deck sounds nice but gets crappy reception right now.
Old Jul 26, 2001 | 07:26 AM
RED92's Avatar
Topduarte-
I'm getting my CD player today (hopefully) so I haven't seen it in person, but the pictures I saw are just as you describe. Looks like it will work fine with no wiring changes, just some extra inputs available on the CD player.
Alex
[This message has been edited by RED92 (edited July 26, 2001).]
Old Jul 26, 2001 | 12:56 PM
topduarte's Avatar
Transmission: auto
Guys,
Thanks for the info.
I am at work now, so I do not have my deck with me but the extra set of pins on the factory cd player is not grouped with the other 4 sets.
Also, there is some indentations on the outside frame of the cd player that show a number and describe each of the wires.
I will see what mine says tonight and pass them on.
I will probably get anxious and hook up the cd player either tonight or tomorrow.
Thanks for the info!!!
Manny
Old Jul 26, 2001 | 12:57 PM
topduarte's Avatar
Transmission: auto
Guys,
Manny
Old Jul 27, 2001 | 09:16 PM
topduarte's Avatar
Transmission: auto
I just installed the new factory cd player and everything plugged right in but the cd player does not work?
Do I need some type of code to initialize it?
According to the seller (Chevy dealership n Ohio), it was never installed and sat in its parts dept. for the last 10 years.
I bleive them because it was sent in the orignal box from delco and wrapped in the orignal plastic and foam.
I am posting another topic on how to initalize it.
Any help would be greatly appreciated it!!!
Manny
Old Jul 31, 2001 | 10:27 AM
RED92's Avatar
Got mine in, went through the sequesnce in the manual to unlock it and it works great, all wiring matched up perfectly.
Alex
Old Jul 31, 2001 | 01:41 PM
topduarte's Avatar
Transmission: auto
Alex,
I got mine to work on Saturday after I reset the codes.
Can you make me a copy of the manual you have? I would really appreciate it!!!
Email me at mlduarte@earthlink.net and I can send you some money for the trouble and shipping.
Let me know!!!
Manny
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
