SPL?
Old Feb 1, 2001 | 06:39 PM
Garmer's Avatar
SPL?
Can somebody please explain this to me? I know its a dumb question for you people that know a lot about car audio, well i dont! So can anybody help me?
Old Feb 1, 2001 | 08:10 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
SPL. Sound Pressure Level. Basically it's just what it says. It's the level of pressure created by the sound. Sound waves don't move through the air like the traditional sine wave you think of going up and down. It actually moves through like a shock on a slinky would, with a series of compressions and rarefractions. When it compresses the air, it creates a high pressure region, and when it rarefracts, it creates a low pressure region. A special microphone hooked to an RTA measures this pressure in a fairly conventional way (i.e. it's a regular microphone).
In different competitions, the rules vary which makes it hard to compare SPL readings from one car to another unless they were both done in the same sanctioned style show. For example, IASCA requires the microphone to be in a very specific position on the passenger side of the dash board, and that a certain track from a specific selection is played. This ensures consistancy. If you roll down the windows it gets higher in many cases, so this is not allowed. In other types of competitions, usually called "outlaw" the mic can go anywhere, including right next to the sub. Obviously this creates BS numbers that don't mean anything. Other local style shows simply drape the mic over the rear view mirror. This is fairly useful to compare one car to the next, but the results will not be compatible with IASCA style results, so they still can't be compared between events. Complicated, hey?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 2, 2001 | 09:15 PM
Garmer's Avatar
Damn that crap is confusing!!! So I am assuming that SPL is a good thing?!?! Can you have to much?
Old Feb 3, 2001 | 01:10 AM
Jim85IROC's Avatar
It depends on what "too much" is. Can you have too much horsepower? It depends on what you're using it for. In terms of hearing damage, you can absolutely have too much. Prolonged exposure to 90dB can cause perminant hearing damage. Momentary exposure to 140+dB can cause INSTANTANEOUS deafness. 140dB can be reached with 2 subs and a strong amp. There are even some cases where cars have reached those levels with 1 sub.
The IROC Homepage
Old Feb 3, 2001 | 09:51 AM
Garmer's Avatar
Jim, how do they measure db? What do you think my system hits.
2 12' Kicker CompVR's
IX702 Kicker Amp
Clarion Head Unit(30 X 4 channnel)
the other 4 speakers are stock.
[This message has been edited by Garmer (edited February 03, 2001).]
Old Feb 3, 2001 | 10:44 AM
Jim85IROC's Avatar
They measure it just like I stated above. With a microphone feeding into a RTA (real time analyzer). It's tough to say what your system will hit because there's a bunch of variables, but I hit 141.1 with 2 12" Oz subs being powered by a Kicker ZR600. Had I tuned it for SPL I could have approaced 145, which is pretty good for a pair of 12s. In general, 2 good 12s in a good box, pushed by a good amp will get you in the range of 135-140.
The IROC Homepage
Old Feb 3, 2001 | 03:14 PM
Garmer's Avatar
Thanks Jim, this summer I think I might go and get that measured! How much do they cost?
Also how many watts and RMS,does your amp put out?
Old Feb 3, 2001 | 06:11 PM
Jim85IROC's Avatar
How much does what cost? An RTA? About $3000. Just find a shop that has one or join a local dB Dragrace.
My amp is rated at 150x2, but according to the birth certificate, the amp put out 871 watts into 4 ohms bridged. I'm running at 2 ohms bridged though
The IROC Homepage
Old Feb 3, 2001 | 08:18 PM
Garmer's Avatar
How much would going to a car show, where you can bring your own car in and get it checked to see how many db's it can put out.
Old Feb 3, 2001 | 10:46 PM
Jim85IROC's Avatar
I paid $10 for the Kenwood dB Drag Race when I entered my car a couple years back.
The IROC Homepage
Old Feb 4, 2001 | 01:01 PM
85TA-AZ's Avatar
hey i was juts wondering if two rockford 12 inch rfz pushed by an orion cobalt 304 could do any ear damage?
85 Trans AM
305 5sp
180,000 miles
KYB sturts front shocks rear
polyurathane bushings
solid panhard bar
new world class t-5
new clutch
Old Feb 4, 2001 | 02:05 PM
Garmer's Avatar
85TA-AZ, I am by no expert on this, but i would say anything can give you hearing problems, if you turn them loud enough!
Old Feb 4, 2001 | 03:53 PM
Jim85IROC's Avatar
Your lawnmower can do damage, so Yes, 2 12" subs can most definately do damage.
The IROC Homepage
Old Feb 4, 2001 | 10:14 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
What? Huh? NO I DON'T WANT ANY CHEEZE!!!
If you have cheap quality equipment, and it pumps lots of distortion, you'll cause more damage.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 5, 2001 | 02:56 PM
myposcamaro's Avatar
'cheap quality'?????
Old Feb 6, 2001 | 02:30 AM
stingerssx's Avatar
In my opinion, audio bahn, thump, jdl, flea market equipment. The amps that are rated at 1900 watts, that measure out to be 2"x4", and use 22 guage power wire. Stuff like that will pump out alot of distortion, and kill your hearing faster. Even at lower volumes than better quality stuff.
benoit454
Car Audio
26
Mar 5, 2004 06:39 PM
330hp_91RS
Car Audio
Oct 24, 2003 12:50 AM
89blackGTA
Car Audio
Jul 3, 2003 11:22 AM
My86Firebird
Car Audio
Jun 24, 2003 06:05 PM
harry's91rs
Car Audio
17
Dec 23, 2002 05:12 AM
