Over powering subs
Old Feb 21, 2001 | 08:47 PM
88_TAOD's Avatar
Over powering subs
Here is my question. I just bought an alpine 2200 watt amplifier(power acoustik), and 2 MTX 8000 4 ohm subs. Now if I run a 2 owm load on the amp it productes 850x2 rms. The subs are rated at 500 or so rms. So will this kill my subs or will they be able to take the beatin. THe mothers are going to pound.
jason
1988 Pontiac Trans Am GTA
350 tpi
BEST ET 15.4
Old Feb 21, 2001 | 09:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It'll be just fine. That amp only makes that much power .000001 seconds before nuclear meltdown.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 21, 2001 | 09:09 PM
88_TAOD's Avatar
What does that mean??
Old Feb 21, 2001 | 10:19 PM
9177's Avatar
I think he means that amp doesn't make that much power
Old Feb 22, 2001 | 10:23 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
yeah the power acustic amps dont make that power that they say they do.
youll be fine
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE <A HREF="http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS" TARGET=_blank>http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS</A> SUCK
Old Feb 22, 2001 | 01:03 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I have a Power Acoustik amp, and while it's a good basic amp, there is no way that it would compare to my Alpine MRV 1000.
MTX are good speakers, especially the higher end like the 8000 series. You can almost dump twice as much power as it's max. Although, it won't last too long. But with that set up, you won't have any problems.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 22, 2001 | 08:19 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Your speakers will be fine so long as you adjust the gain (power output ****) on the amp properly. This basically meansto set the radio's volume as high as you'll ever want to turn it up to then slowly turn the amp's gain up till the subs start to sound funny. They will sort of sound like a baby rattle. This is known as distortion and this is what will break your subs. As soon as they start to distort turn the amp's gain down till they stop then leave it alone.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
Old Jul 21, 2003 | 11:53 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Also, remember all amp ratings are max, it's not going to have a constant output of 850watts
Old Jul 21, 2003 | 12:14 PM
onebadwagon's Avatar
mine does.
adam
Wylecoyote08
Oct 1, 2015 09:18 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
