box volume problem
Old Mar 14, 2001 | 06:33 PM
CamaroZ_85's Avatar
box volume problem
I seriously want to get a set of Boston Pro Series 10's for my car, problem is the box that i have right now is .75 cu feet and they call for .5 cu feet....is there anything i can do besides hack up my box to put these subs in????
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Mar 14, 2001 | 06:38 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
You could try adding 2x4s inside the box to take up the extra space.
Old Mar 14, 2001 | 08:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
.75 will be fine for those subs. Getting a little bigger will give better low frequency response.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 14, 2001 | 10:07 PM
Drufire's Avatar
if it is an enclosed box you can use packing foam.. and it helps alot
Drive A BowTie And Leave The Suit At Home!
Old Mar 15, 2001 | 03:08 AM
Belker's Avatar
Add bracing !!!
Add bracing !!!
Add Bracing !!!
Old Mar 15, 2001 | 08:44 AM
dallasiroc's Avatar
PolyFiber Fill.
Or fiberglass isulation. Line the inside of the box and you will be fine
Old Mar 15, 2001 | 09:33 AM
Jim85IROC's Avatar
Poly fill fools the sub into thinking it's in a LARGER enclosure, not smaller. Plus, the effectiveness of poly fill is debatable but the general consensus among knowledgable installers is that although poly fill does produce measurable differences in the T/S parameters, they are too minor to be audible.
The IROC Homepage
Old Mar 15, 2001 | 09:34 AM
CamaroZ_85's Avatar
jim, thats what i thought about the polyfill...thanks! will foam do the same?????
Old Mar 15, 2001 | 09:59 AM
dallasiroc's Avatar
thanks jim for correcting me. I read the post wrong. Boy was I bass-akwards
Old Mar 15, 2001 | 03:49 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CamaroZ_85:
jim, thats what i thought about the polyfill...thanks! will foam do the same?????</font>
Depends on the density of the foam. The problem with foam is that it may exhibit different characteristics at different pressures, which could potentially result in some fugly situations. In general, I'd assume it would do too little to be audible, just like poly-fill. I'd try the box as-is first, and if you find the bass to be a bit too thin, you can always screw some 2x4s in there to take up space.
The IROC Homepage
Street Lethal
Apr 30, 2019 12:14 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
overdriv
Aug 20, 2015 03:52 PM
