Need help!
Old Mar 3, 2021 | 08:30 AM
EightyFiveAgain's Avatar
Car: 1982 camaro berlinetta
Need help!
Hi everybody, new account because I couldn't log into my old one. Just need someone to confirm this stereo deck will fit in my car. I have a 1982 camaro berlinetta with a Delco in it without cassette and eq. The deck works but was crackling like the speakers were blown. I brought it to my local audio shop, replaced the speakers but still had the same issue. The tech at the shop told me it's the deck causing the problem and told me to get a new one. I want to keep it era appropriate. Personally not a fan of new decks in old cars. So I've been online looking and i found this one. I was wondering if anyone can confirm it will fit and work? It looks like it's the same size, but I'm not sure.
thanks everybody
Old Mar 5, 2021 | 09:37 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Need help!
That radio will fit and can be installed in your console with no modifications to the console. It will use the same brackets and hardware as your existing Delco head unit.
Your 82 will have dash plugs that look like this:
That radio might be from a Cavalier or maybe a Celebrity,...... depending on the year it was pulled from it might require the 82-87 style plugs or it might require the 88-96 style plugs.
If your car still has the original radio plugs still intact than you can buy a plug-&-play adapter ( as shown in the pic above ) so you can install almost any 82-96 head unit into your car. If your original plugs have been cut-off at some point,... then you could just splice wheat-ever plugs you need to the dash harness. ** The antenna also changed from "big" to "small" plug in 88,... there is also an adapter available for that too if needed.
'87IROCZOWNER69
Car Audio
Jun 14, 2010 07:41 PM
Nihilithik
Car Audio
Jun 18, 2009 05:08 AM
airjordan6906
Car Audio
Dec 30, 2006 07:47 AM
bum
Car Audio
Dec 11, 2006 09:11 PM
z28cmr83
Car Audio
May 9, 2004 01:26 PM
