1986 UQ7 Radio Replacement Help
Old Sep 1, 2021 | 04:16 PM
dmadion's Avatar
Hi all,
Looking for help identifying the correct original deck for my 1986 TA. Through my research (thanks to this forum), I learned it has a UQ7 system, but I can't seem to find clarity on which original radio deck would be stock. I want to remove the aftermarket Pioneer CD player the previous owner installed, but want to make sure I'm looking for the right console. Any help would be appreciated in identifying and pardon if this has been asked in earlier threads.
Thank you!
Old Sep 1, 2021 | 08:17 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1986 UQ7 Radio Replacement Help
The Sub-woofer system (UQ7) was used with any of at least 3 different Radios,.. UM6 ( basic cassette ), UX1 ( EQualizer radio ), or UT4 ( push button ). The only way to know what radio your car originally had is to look for the radio code on the RPO tag.
** have never seen UQ7 installed with a non-cassette (UM7) head unit; might or might not have been offered with that radio !
Old Sep 2, 2021 | 07:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Here is a list off radios available for 86
Old Sep 3, 2021 | 09:52 AM
dmadion's Avatar
Thank you both! Very helpful,
Old Dec 22, 2021 | 10:24 AM
dmadion's Avatar
Hi again,
Finally getting going on my project here - so if I'm reading this correctly, I need a UX1 if I want to return to original radio. Thank you again for your help.
Old Dec 22, 2021 | 12:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
Originally Posted by dmadion
Hi again,
according to the order sheet that I posted you can use any stereo radio that was used for 86 and other years.
Old Dec 22, 2021 | 06:11 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The UX1 radio is like this one with *****.
Dark grey face with lighter grey *****/buttons just like the one pictured.
UT4 is similar, but no *****, all touch buttons.
Camaro also had a similar radio, but all black, so don't grab the wrong one.
Old Dec 23, 2021 | 12:28 PM
dmadion's Avatar
Thank you both - and pardon my ignorance, but am I reading my parts list correctly in that if I wanted to return to the original radio it would be a UX1? And that mantaguy's parts list includes other options that would also fit?
Old Dec 23, 2021 | 12:56 PM
LAFireboyd's Avatar
Yes, your car's SPID label shows it came with the UX1 radio option, and that's the radio that I posted. Pontiac is grey, as I posted. Camaro is black. But any radio up to 1987-88-ish should fit.
Old Dec 23, 2021 | 09:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
100 0986
And this is a UM6 Radio that my TA came with(the jack was added later)
Old Dec 27, 2021 | 09:37 AM
dmadion's Avatar
Thank you!!
AtomicKarate_16
Car Audio
May 7, 2021 11:03 AM
richcz28
Car Audio
Aug 9, 2009 05:33 PM
my89
Car Audio
Jul 30, 2008 11:35 PM
koby
Car Audio
Apr 30, 2005 11:42 PM
84Olympic
Car Audio
Nov 7, 2000 08:28 AM
