Stock radio dimensions
Old Mar 18, 2001 | 10:58 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
If you have your stock AM/FM Cassette w/ EQ out of your dash, could you post the bezel & chassis dimensions? Also, does anyone have the maximum chassis dimensions that would fit into the dash?
My '89 IROC is currently stored where I can't get at it immediately and I'm looking into an aftermarket unit.
I'm wondering if a unit w/ the following dimensions would fit w/o a lot of custom work.
Chassis: 7 1/8"W x 6 1/2"L x 3 3/4"H
Bezel: 7 7/16"W x 4"H
Thanks for your replies.
89 IROC Z28
305 TBI / Auto
Stock bumper to bumper
Old Mar 19, 2001 | 11:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Dimension specs are fairly useless. Cars use standardized sizes. GM uses a 1.5 DIN sized radio, which means the height is 1.5 times as high as a standard single DIN radio. Most aftermarket radios are single DIN units and need an adapter to fit into the dash of a GM vehicle. Pioneer, Alpine and a couple trash companies (Jensen and Audiovox come to mind) make 1.5 DIN units that are a direct fit. All single DIN units need an adapter.
Depth is also an issue. You don't have much depth in a camaro dash, and a single DIN radio is going to be a lot deeper than the stock radio. The Camaro mounting kits make the radio stick out about 3/4". This can only be avoided by cutting away part of the heating ducts in the center console and removing the steel bar that the stock radio tab slides into.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 19, 2001 | 07:14 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
From an '87 IROC
Chassis 7 15/16 W x 5 H x 3 3/8 H
Bezel 8 1/8 W x 5 1/8 H x 3 1/2 H
Old Mar 19, 2001 | 09:45 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Thanks 87KEVROC. It seems the unit I'm after will fit. Check it out:
http://www.evisteon.com/b2c/cd6_index.htm
After seeing one in an Explorer I can't get it out of my mind how good it would look & function in an IROC. The guy w/ the Explorer loves the unit.
I think it looks a whole lot better than the units typical car audio companies are churning out for our cars. They claim they look better than the standard DIN units, but most are ugly & none fit w/ the styling of our interiors. That's to say nothing of the price they want for them.
Old Mar 19, 2001 | 10:05 PM
Jim85IROC's Avatar
Wait until you see how much that radio is going to cost. Installation is also going to be a huge pain in the *** .
The IROC Homepage
Old Mar 20, 2001 | 11:39 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
I've emailed a local distributor for pricing and will post the results when I get them.
Based on the numbers 87KEVROC posted, this unit is slightly smaller than the OEM radio in all dimensions. So I don't anticipate it will be a big hassle to get it to fit or make up for the minor size diffences.
Old Mar 21, 2001 | 07:34 PM
Belker's Avatar
As far as visual appeal and a "stock look" ... I like it.
Old Mar 24, 2001 | 11:28 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
The local distributor quoted me $699 for one. I'm going to look into prices from other sources (factory direct, other distributors, dealers, etc.) and post what I find out.
Also, I noticed I was wrong about all the dimensions being smaller than the stock radio. The chassis height for this unit is 3/8" taller. That'll definitely need to be looked into before laying down any money.
Old Mar 25, 2001 | 12:01 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Here's a nice shot of the unit ...
<img src="http://www.evisteon.com/b2c/images/cd6.jpg" alt="Visteon CD6 Music System">
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
arod231
Aug 16, 2015 02:51 PM
Spd-Kilz
Aug 15, 2015 12:12 PM
