Looking for double din bezel
Old Oct 26, 2021 | 11:14 AM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Hi everyone,
I'm looking to swap out the bezel on my 1987 trans am for one that will accommodate a double din. I've seen 3d plans online for a bezel with the checkered pattern. Does anyone on here make/sell them? Alternatively any good suggestions on how to cut the stock bezel cleanly?
Old Oct 27, 2021 | 02:15 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: Looking for double din bezel
I modified my first one by cutting the stock bezel to fit the double din height and used the pieces i cut to fill in the sides where the DD is not as wide as the factory radio. I have since had some 3D printed and the look is much cleaner. I did still wrap mine as the rest of my dash panels were already done that way.
My other car i used some thin aluminum as the face over the bezel and cut the hole accordingly. this was done primarily to fit the bigger 10" screen but worked very well. Again it was wrapped to hide the mods done to the factory bezel.
I am sure someone on here has some printed for sale if you want the factory checkered look. mine were all just plain printed
Old Oct 27, 2021 | 02:30 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
https://www.etsy.com/listing/8780627...8aAs-xEALw_wcB
Old Oct 29, 2021 | 09:07 PM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Thank you both! I actually think I found someone who can print with the tron pattern and a glossy finish. I will post it up on the site when I eventually get it installed.
Old Nov 7, 2021 | 07:43 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Please do, I am in the market for one that looks as close to factory as possible as well.
Thanks!
Old Nov 8, 2021 | 10:49 PM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Thanks!
I placed an order for a double din with the tron design. Should hopefully receive it in a few days was pretty reasonable. Once I take a look at it I'll share here and share the ordering details
Old Dec 2, 2021 | 08:13 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Did you ever get the bezel and install it. I would love to see how it turned out. I am going to be doing a double din install in the spring.
Old Dec 15, 2021 | 09:40 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
id love to see the final product too, did you ever receive it?
Old Dec 17, 2021 | 12:47 AM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Apologies for the delay all. I received the bezel but the manufacturer screwed up the texture. I have the tron pattern but it should have a glossy finish; instead it has the camaro rough finish. Trying to get this resolved. Again will share some photos etc once i have the right piece.
Old Dec 20, 2021 | 03:24 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the update. I look forward to seeing the finished install. I want to go double din in the spring on my 87 Trans Am.
RSluvr
Camaros Wanted
Jun 3, 2007 11:03 AM
