12" hx2 and American pro bass machine
I am getting a 12" RF hx2 today and I already have an American Pro Bass Machine
model # VS1820 It puts out 800w at 2 ohms
I am told that this amp is a comp amp and only works at 2 ohms. How many ohms is the hx2 and how can I bring it down to 2 or real close to 2.
The best I can rember the sub is 2.10x2 ohms
So that is like 4 ohms right? Is it possible to bring one sub down to 2ohms.
Please help me b/c I am going to hook it up tonight and I REALLY don't wanna blow anything.
Please help,
Joey
Please help,
Joey
Acccording to the American Pro web-site the V.S. 1830 is rated at 120w x2 @ 4 ohms or 175w x2 @ 2 ohms or 350w x1 bridged mono @ (?) ohms. The 800w rating is a meaningless "peak-power" rating that they somehow came up with (ignore peak power ratings because they are just marketing ploys).
Anyway ... the amp should be stable a 4 ohms, so you don't need a 2 ohm load, and you shouldn't worry about hurting the amp with a 4 ohm load. Connect your sub by bridging the amp for a 4 ohm load.
Also ... there is no way to make a SVC 4 ohm sub be a 2 ohm load. You can add another sub and wire them in parallel. Or you could have a DVC sub with 4 ohm coils and wire the coils in parallel.
[This message has been edited by Belker (edited March 25, 2001).]
first of all it is a 1820 not 1830 what would the dif be? Second of all The hx2 is a DVC.
Here are more specs on it. What does that mean it is a 8 ohm speaker but can be wired to a 4.2 ohm rating?
12" Punch HX2 DVC Woofer - 4 ohm x 2
4-Layer, 3.0" Voice Coil
Aluminum Former
BART Santoprene Surround
CONCealer Gasket
Spruce Pulp Paper Cone
Hyper-extended Pole Piece
Aero Vent Base Plate
Magnet Bumper
Punch LX Cast Basket
Progressive Dual Laminated Spider
[Specs]
Model RFD1212
Description RFD1212
Nominal Impedence 2 x 4 Ohms
RE (DC resistance in ohms) 2 x 2.10 Ohms
RMS/PEAK Power 500w rms / 1000w peak
Sensitivity 88db
FS (Hz) 26Hz
QMS 7.30
QES 0.52
QTS 0.39
SD (Cone Area) 87"^2 (0.056m^2)
VAS (Cubic ft.) 4.238
XMAX (inches) 0.55"
Voice Coil Diameter (inches) 3.0"
Mounting Depth (inches) 5-13/16"
Thanks for your help but someone now please reply given the new info.
Joey
Aluminum Former
CONCealer Gasket
Magnet Bumper
[Specs]
Model RFD1212
Description RFD1212
Sensitivity 88db
FS (Hz) 26Hz
QMS 7.30
QES 0.52
QTS 0.39
XMAX (inches) 0.55"
Joey
bigjay89gta
10-15-2015 08:04 AM
