Camaro Double DIN radio brackets from Screaming Chicken
Just added these to the website today. To install a Double DIN radio in your 1982-92 Camaro you need a radio, bezel and some way to mount the radio - this kit provides what you need to mount the radio. To gain clearance for the bigger radio you normally also have to modify your heat/ac controls, this kit also provides brackets for that purpose. Brackets are aluminum which makes the radio more sturdy than plastic. They are slotted so you can make small adjustments to get the radio exactly where you want it, you can move the radio up/down and forward/backward. We tested the brackets with a couple of the more popular 3D printed bezels currently available. This kit includes radio and heat/ac control brackets plus new hardware or you can use the factory hardware. Will not fit 1985-92 Firebirds unfortunately. Radio brackets will fit 1982-84 Firebirds, but HVAC brackets will not. Bezel is not included. $28.95
1982-92 Camaro Double DIN Radio Install Brackets (screamingchicken.com)
The following 3 users liked this post by scfbody:
T.L. (01-27-2022)
Re: Camaro Double DIN radio brackets from Screaming Chicken
I am planning to use the 84 ta parts car center console to see if I can modify the metal brackets for double din.
These mounts should work for radio placement, but you need to move the ac controls and trim the metal frame on the console itself.
The radio brackets should work, may need a little filing at most but the heat/ac control brackets won't work. Can you send/post some pics of how your heat/ac mounts?
You need a kit like this for the 82-84 firebird. I can not find any info on who made it though.
T.L. (01-27-2022)
looks like a quality kit there. I'm going to see how the Camaro kits sell and go from there. Would be good to have bezels to sell also. Plus I would need a center console for test fitting, so have to find one of those first. I have a '85 TA but totally different on the radio mount.
I will have to pull it. We are planning to tear it down during spring break.
Brackets have quite a bit of adjustment so you can get radio flush with the bezel, recess it and have it come out some. Went with flush on my car.
Axle/Gears: 9-bolt/3.45
Wait a minute! You're Screaming Chicken, not Thundering Herd! You're offering brackets that fit Camaros, but NOT Firebirds?
This is something we've been needing. People who do 2DIN installs never show how they mount the radios. We only get finished pictures with the bezel installed over the radio. No doubt most of their mountings are probably pretty unsightly.
I can understand why the heat/ac control brackets might not fit Firebirds, but why wouldn't the radio brackets work? All of the radios of the generation use the same mounting brackets on the sides of the radios, and radio fitment is interchangeable from car to car, whether it's an 82-92 Camaro, an 82-84 Firebird, or an 85-92 Firebird. A radio from an 83 Camaro will fit into an 87 Firebird, and so on. I'm not talking about wiring connections, but simply radio fitment into the car's dash/console/pod. So if those radio brackets fit one 3rdgen, then they should fit all 3rdgens.
Granted, an 85-92 Firebird radio pod has a "shelf" that separates the heat/ac controls from the radio, which can make 2DIN fitment more complicated, but there are plenty of 2DINs already installed in those pods, so 2DIN will fit. Your brackets' adjustability should make fitment easier.
Nice product. I'll probably get a set.
T.L. (01-29-2022)
Car: 1987 IROC Camaro Z28 G92
Engine: 305ci
Transmission: TKO600
Axle/Gears: 9 bolt
Ordered. Thank you for supplying parts like these!
Car: 87 T/A
I'm planning a double din install in the spring on my 87 TA. I would buy a set of brackets if you make them. Firebirds should really get every product before Camaro since we're better looking.😊
Just kidding.
Just kidding.
I agree on that. Who is making a good 1985-92 bezel? The brackets have to work with the bezel so I need one of those for design/testing. I've seen 1982-84 TA bezels but haven't seen any 1985-92 for sale.
Car: 87 T/A
https://www.ebay.com/itm/15476197767...gAAOSwEuxhX0SX
Here is a link for 1 on Ebay if it helps. I can't vouch for the quality. They show up on Etsy sometimes also.
Car: 87 T/A
The grid pattern would be nice. There is a pattern to 3D print on thingiverse with the grid pattern etched in.
https://www.thingiverse.com/thing:2249678
The only problem I see with 3D printing is getting the metal clips for the ears. I also thought about just wrapping 1 with some brushed aluminum wrap in a color to match the stock bezel. ( I saw this in another post to be fair)Wrapping it would do away with trying to paint it and still give a quality look.
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
I'm actually in the process of making them. They should come out similar to the Camaro plate as far as color and sheen are concerned.
Good deal! I'm using your Camaro bezel in my car; I like it better than some other ones I bought. I bought a couple of Camaro bezels from different suppliers to make sure the brackets worked the same.
Here's the sister file to the one posted by TABBOO.
Firebird 85-92 double DIN radio bezel - analog by cehbra - Thingiverse
Both were created by Cehbra in this thread. Cehbra also created a pattern in this thread to apply to this plain bezel so it would look factory.
Discussion: Texture improvement on 3D printed double DIN radio bezel (Firebird) - Third Generation F-Body Message Boards
And here's a more recent thread by someone else. His file is based on the lesser-produced smaller HVAC opening found in digital dash cars, rather than the vastly more common standard size opening, but I'm not sure he was aware that there were two different bezels when he created it. Also within this thread is, yet, another version created by someone else. It's too deep, but it seems to fit ok. I've also seen these deeper versions on alibaba, which is where some other members have reported to have gotten one.
Firebird double Din radio bezel - Third Generation F-Body Message Boards
DynoDave43 (02-07-2022)
Car: 87 T/A
Axle/Gears: 10 Bolt 2.73 Open
Crutchfield.com currently has some Kenwood, Jensen, JVC and a couple of other brands in stock. Looks like no Sony or Alpine anywhere currently.
I was able to get a center console from someone nearby and have a bezel from Unleaded-designs on the way so should have 1982-84 Firebird brackets in the near future. I'll be sure to post progress on the forum.
7thdarkangel (02-17-2022)
We're now selling bezel and brackets as a combination or brackets by themself. The bezels are from Unleaded Designs and we make the brackets. Brackets and bezels are in stock currently. We also got a double din 1982-84 Firebird bezel from Unleaded and found a used console to start developing brackets for. The Firebird brackets are a lot more involved than the Camaro so might be a month or so before they are ready, but they are in process.
1982-92 Camaro Double DIN Install Kit (Bezel & Brackets) (screamingchicken.com)
Car: 87 T/A
We have been very happy with the quality of the bezels from Unleaded so we are going to stick to making brackets for the bezels he offers. He mentioned working on a 1985-92 bezel but I don't believe it is a reverse set up. We're currently working on the 1982-84 Firebird brackets.
#42
Very nice. Molded, huh, not 3D printed? So it'll have that smooth, somewhat glossy, black face? No sanding, no painting? Just pop the clips on the back mounting tabs and install it right out of the box? I like it.
#47
We made a small change to the Camaro brackets and will get 100 of the new design on Monday. We added more adjustment so hopefully they will work on a Firebird. We will be able to do some testing next week with a 1982-84 Firebird bezel and will update on this thread.
#48
First part out of the mold. Need to do a little more vent work but looking good so far. Going to work on the vents tonight as well as testing adding the tron pattern.
The flashing and mold release has not yet been cleaned off this part if you wondering what the shiny smudges and weird edges are.
front
iso
followed Cehbra's lead with the emblems on the back.
front
iso
The following 2 users liked this post by 7thdarkangel:
DynoDave43 (04-19-2022), scfbody (04-19-2022)
#49
Car: 87 T/A
Nice work it looks great. It will be interesting to see how the Tron pattern works out for you. It would be a nice addition, but the bezel looks great even without it.
Nice attention to detail on the back side, nobody will ever see those emblems on the back but they speak volumes about your dedication and craftsmanship.
7thdarkangel (05-03-2022)
#50
Firebird plates will be up on the site later today. Availability will be limited for the time being. They are a pain to mold. No updated on the tron pattern yet. Going to be trying out some new software this week.
DynoDave43 (05-03-2022)
