Antenna plug not fitting into stock GTA Radio?
Old Jun 25, 2022 | 01:30 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
I can’t get the antenna to plug into the new/used GTA UT4 radio? The previous head unit was a pioneer CD player. I am wondering if I just need an antenna adapter?
Here are some photos:
Back of stock UT4 radio.
The antenna in the car that won’t fit.
I am wondering if the radio I just purchased is from an 89’ and that my car being an 88’ may have a slightly different antenna? I am not going to force it and break something. Any help on this is appreciated.
I also wonder of someone may have modified the male radio connector, it looks like a pro job on the pioneer install whenever that was, so maybe instead of using an adapter they just put a new connector on?
Old Jun 25, 2022 | 11:57 PM
Engine: 5.7 L98
Re: Antenna plug not fitting into stock GTA Radio?
Solved with the help of another member Hessm70, looks like all I need is the mini barb adapter and I will be in business. Someone likely swapped out the antenna at some point.
Old Jun 29, 2022 | 11:09 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
www.crutchfield.com
Has the adapter you need.
I also needed the big pin to small pin adapter plug for the speaker wire plug.
I had to get both for my 84 when I swapped in a newer Delco am/fm/cd unit.
Lauer
Car Audio
Jun 4, 2018 12:07 PM
88fastgta
Car Audio
16
May 10, 2009 06:26 AM
zr1 32 16 405
Car Audio
Apr 14, 2003 09:08 PM
89 CamaroIROCZ
Car Audio
Mar 12, 2001 01:53 AM
