Better sound by using a better amp??
Old Jan 25, 2002 | 03:51 PM
87firebird's Avatar
Right now I have two Mtx thunder6000 10's that are rated 500 peak and 250 rms and I have a mtx thunder4250D amp that is rated at 250 watts x 1 at 2 ohms( box says 350 watts) My question was if I get a bigger amp, say mtx thunder6500D, would I get alot better sound or is it a waste of money?? thanks
Old Jan 25, 2002 | 05:14 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
With amps more amperage means louder, not necessarily better sound. There's the crap in crap out theory whcih i believe in. Yer head unit has to be up to par, if the sound comin out is bad, its gonna be amplified and made to sound worse, because thats what an amp does. The quality of the speakers also will play a small role.
Old Jan 25, 2002 | 06:53 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if you're amp is of good quality and powerful enough to power the subs, then you wont hear much of a difference. however, by having more power, you can lower the gains a bit, making it less likely be clipped or distorted
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
