Good tip for anybody running wire
Old Jan 27, 2002 | 09:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
After you find that perfect spot in the firewall to drill a hole into for your power wire, make sure to double and triple check that you're not going to hit anything.
Today I picked a spot right under the spot where the clutch master cylinder goes through the firewall. I checked both sides, then drilled an 1/8" pilot hole. Plenty of room all around the hole, so I got the cone drill thingie out (The drill that hogs out progressively big holes) and drilled most of the way through, then got out to make sure I was still safe. I had brake fluid dripping all over the place. I drilled right into the bottom of the clutch master cylinder. I drilled on a bit of an upward angle, and the master cylinder sits on a downward slope. Drilled right through the fugger.
Old Jan 28, 2002 | 08:09 AM
GndPrx's Avatar
"I got the cone drill thingie out (The drill that hogs out progressively big holes)"
UNIBIT
That sux about the maser cyl though...
Old Jan 28, 2002 | 12:32 PM
mcconahay37's Avatar
Yet another thing to add to the "What NOT to do when working on your car" post on the tech board. That sucks man.
specialized
Jun 18, 2022 09:26 AM
rocn7roc
Sep 21, 2021 02:16 PM
midge54
Dec 27, 2019 04:14 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
