2 ohm dvc
Old May 12, 2001 | 08:04 PM
miked's Avatar
2 ohm dvc
I saw that you can get the 2001 rockford hx2's with either duals 4 ohm or dual 2 ohm voice coils. (Pretty sure they were hx2's). What ohm loads on the amp could you pull off with 3 of the 2 ohm voice coil DVC's?
Old May 12, 2001 | 08:15 PM
IROCketZ28's Avatar
Wiring the coils in parallel would give each sub a net load of 4 Ohm. Then, wiring the subs in series would drop it down to 1 Ohm, or wiring the subs in parallel would bump it up to 12 Ohms.
Old May 12, 2001 | 09:34 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Wiring the coils in parallel on three speakers would give each one 1 ohm, then wire the 3 in series and you'll have a 3 ohm load.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old May 15, 2001 | 02:24 AM
Tigger84TA89BIRD's Avatar
The actual ohm load on three DVC's wired in parallel is about 1.3 ohms... sony's new 3001 series amp is perfect for that kind of setup and has about 1000watts peak, only 450 bucks +/-...
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
Shane87irocz
Sep 22, 2015 06:21 PM
