CD Changer in center console?
Old May 26, 2001 | 02:34 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
When I install a new stereo in my car, I want a MiniDisc head unit but I also want to be able to play CDs in my car. What are my options? I was thinking about getting a Kenwood CD head unit and then their add on MD unit underneath it, but thats Double DIN and I wouldn't be able to install it. Or I was thinking about getting a Sony or Kenwood MD head unit with a Sony or Kenwood CD changer in the center console. I don't think its big enough to fit a CD changer in it though. Has anyone done it before? How did you do it and do you have any pics? Any help is appreciated. Thanks in advance.
Edit: spelling.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
[This message has been edited by MetalliCamaroRS (edited May 30, 2001).]
Old May 28, 2001 | 12:36 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Anyone?
1992 Camaro RS
My 1992 RS
Old May 28, 2001 | 03:03 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
I dont think it will fit in the console, but im pretty sure you could get it in the rear storage box. Thats where im planning on putting mine.
Old May 28, 2001 | 03:11 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Yeah but I want it in front so I can change CDs without getting out of the car.
1992 Camaro RS
My 1992 RS
Old May 28, 2001 | 10:00 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">Originally posted by MetalliCamaroRS:
</font>
That's what the in-dash cd player is for.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 28, 2001 | 10:01 PM
Car: 1989 IROC-Z
Engine: 383 stroker
But I also want MiniDisc cause most of my music is on MD but my friends have CDs and I have some CDs too. I think I'll just get a MD head unit and no CD player
1992 Camaro RS
My 1992 RS
Old May 29, 2001 | 01:35 PM
myposcamaro's Avatar
i currently have my CD Changer in the rear glove box. Im also looking to mount it somewhere up front.
I was thinking of flush mounting that SOB in the dash panel under the A/C vents??
would this work?
whats behind the panel anyway?
kev
Old May 29, 2001 | 10:33 PM
Lostsol's Avatar
When I got my first changer I was looking for a way to put it in the center console as well, then came to my senses...LOL You can't even cut out the bottom of the console and make enough room for most changers. Some minidisc changers may fit, but the only way I can think that a regular disc changer would fit would be if you were to cut out the console lid and flush-mount it in the console up through the lid. Then it wouldn't be hidden though which I assume is what you're after in the first place; or at least no more hidden than it would be flush mounted in the passenger side dash. Any thoughts on the feasibility of a flush mount console/changer? I'm sure other folks have pondered the idea. My two cents anyway... Take care now...
Old May 30, 2001 | 11:02 AM
DJSexay's Avatar
One idea is to put it in the center cosole, but make a new lid to it that is bigger to allow for the height of the changer. Esp, in the camaro, cause I think the camaro's center console has a little more room than a firebirds. I think most 6 disc changers would fit, but would need an extra 2 inches of height.
Mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
Old May 30, 2001 | 11:39 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
CD changers will not look good mounted under the vents or recessed anywhere in the dash. They are too big and there is too much stuff to remove or relocate if you start carving into the dash. I once thought about mounting it under the dashpad in front of the "wall" area on the passenger side, but then its exposed for every potential thief to see. Then you have to figure out how to run the wires without making a mess.
After much thought I decided on putting the CD-changer in the trunk, out of sight. I really can't see why you would want to change CD's so often it would become tiresome. I have a 6-pack changer which could play for HOURS before I wanted to change discs....imagine how long you could go with a 10 or 12 pack changer?
Maybe you should consider getting an in-dash CD-palyer with the mini disc add-on, and instead of buying any type of changer just buy yourself a CD-RECORDER and burn your own custom CD's to your liking. Just my .02
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 30, 2001 | 11:41 AM
Pukka's Avatar
One more thing. The space directly underneath the center vents makes a nice spot to mount a full DIN component. Its where I mount my graphic EQ. And you could completely hide the wires with minimal drilling of the dash wall.
Ed1LE
Sep 30, 2018 09:14 AM
Lbibb
May 5, 2016 12:00 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
