Where's your brain?
Old Jun 13, 2001 | 06:57 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Where's your brain?
I'm moving the brain of my alarm into the dash area somewhere. I'm not too sure where it will fit best though. Who else has done this? Also, the secondary radar(interior) is going under the console, but there's a lot of metal brackets there. How much will that throw it off? As long as the metal stays under and not around, beside or above, I should be all right, shouldn't I?
Old Jun 13, 2001 | 07:43 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
A good place to install the brain is under the driver's side dashboard, which is another good place to install the valet switch if your alarm comes with one.
The radar, or motion sensor should be placed in the center of the car. You can mount it under or inside of the console and not have any problems.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 13, 2001 | 09:02 PM
GndPrx's Avatar
Actually an even better place is under the dash pad up top. Hard to get to to cut wires should someone break into your car. Just make sure you have backup battery incase they cut the battery lead.
Carl
CarAudio Resources
Damon
Carburetors
22
Aug 28, 2006 02:58 PM
camaro 22
Nov 24, 2001 10:59 PM
formula5
Aug 10, 2001 08:51 AM
Box of Rocks
Jan 16, 2001 01:28 PM
