Underdrive Pulleys w/stereo system?
Old Jun 6, 2001 | 11:17 PM
Rallyssport's Avatar
I got my Power and Amp pulleys in today and im gonna put em on soon. They claim that power and amp pulleys will charge at idle and do fine with a 600 watt system. I just wanted some opinions on that. Oh by the way i got a 92 RS 305 TBI with a stock altonator. Any bodys battery go dead or alt. coulnt keep up when the system was on? Also how much gain did ya get from the pulleys?
Old Jun 7, 2001 | 09:55 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'd also be interested in hearing from anyone who has done this. I've only replaced the alternator once since I have owned the car brand new. However, the stereo has only been in it for about 3 years. I usually go through batteries every 2-3 years, but my alarm system is mostly to blame for that.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 7, 2001 | 10:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My alternator can't handle my system as it is. I couldn't imagine under driving it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 9, 2001 | 02:36 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i plan on gettting a higher amp altinator first before putting theses on. im just to chicken with all my stearo stuff.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
Old Jun 9, 2001 | 05:45 PM
ATTNGETR's Avatar
Car: 86 Iroc
Engine: tree-fiddy
Transmission: hmm..a 700 or a T5..guess!!
All u need is a capcitor and you will be fine,cuz the brunt of the power will be absorbed by the cap
86 Iroc-Z28 350 Edlebrock,Borla,Transgo,B&M,ACCEL,Random Tech,Auburn,Alpine,Rockford Fosgate,Ultra Z's,1LE brakes&swaybars etc....
Old Jun 9, 2001 | 07:26 PM
camaro6spd's Avatar
The idea here is a larger alternator and the biggest battery you can cram under the hood or wherever.
Old Jun 10, 2001 | 03:34 PM
Jim85IROC's Avatar
A cap isn't going to do much if the alternator is outputting insufficient power. A cap helps maintain transients during bass hits, but your overall average power consumption doesn't change. Garbage in = garbage out.
The IROC Homepage
Old Jun 10, 2001 | 10:16 PM
My buddy has a cavalier and hes got 2 15" solo-barics. we were at a spl contest and the first run he hit a 145 with the cap and then he took it out and went back through and hit a 147.
Old Jun 11, 2001 | 12:00 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rallyssport:
My buddy has a cavalier and hes got 2 15" solo-barics. we were at a spl contest and the first run he hit a 145 with the cap and then he took it out and went back through and hit a 147. </font>
If he "burped" the system for the SPL contest, the caps would have helped. If you play regular music for the competition, the cap will be an additional drain on your system after the first 1 or 2 seconds.
The IROC Homepage
Old Jun 13, 2001 | 09:34 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I have the pullies on my car. When I first installed them (before I had a stereo) I noticed a pretty decent improvement. It seemed to launch faster and pull through the power range better, but I don't have any numbers or anything like that.
Later I installed the system and I never really had a charging problem with mine and I was usually running at least 600watts and sometimes 1100+ watts. When I had it running at 1100+ and driving, I would notice a drop in voltage, but only when sitting at a light or something when the rpms were not above 1000 or so. Other than that, I really never had any problems. Now that I don't have a system, I really don't, but that is beside the point!
If you are going to be running 600 watts or so, you should be okay for a while, but I would definitely recommend looking into an upgraded alternator of maybe 130 amps or so, but it all depends. Check with a stereo shop for a better idea of how big to look at. I hope that helps.
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BDR
Nov 7, 2015 03:05 PM
slowsi
Oct 18, 2015 08:49 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
