square sub box volume
Old Jun 18, 2001 | 08:15 PM
Camaro_hunter_d's Avatar
well I am looking to put in a square sub box in my well and was wondering exactly what space was needed inside the box. I have 2 Rockford Fosgate RFZ1812's and I wanted to mount them in the box facing each other. I have close to 4 feet of room between the well walls and I wanted to mount the speakers 3-5 inches into the box and have small ports behind the speakers. I was wondering if I should leave alot of the top removed like 5-7 inches or just put like 4-6 ports in it?... And helpfull info would be appriciated.
Kills to date a 3.1 firebird 2 stop lights in a row.
95 Grand Am
Serveral Honda's
a friends 91 Rustang LX(I know its a 4 but he keeps trin')
Planned mods:
Soon coming 3 inch exhaust, 1.6 rockers, High flow 'Verter, and Ignition system. Along with a complete turbo 4.3 swap planned later this year(hoping to get into the 10's..)
Current mods:
Set of Iroc sway bars front and rear..amazing differance, Air box bottom completely removed allowing my K&N to act like an open element filter.
Lower profile tires, 195/55/15 front 205/55/15 rear handles better.
And a 160 deg thermo for a V8(and yes it works just fine)
Sterio Sony CD head unit and 9 band EQ, Boston acutics 4x6 dash, Alpine 3 way 6x9 sail, California sounds active crossover, Kroiiler 600 watt amp powering the 'pines and Bostons, 600 watt Jensen powering 2 Rockord Fosgate RFZ1812 subs. And all this cost less then $575...
Old Jun 19, 2001 | 07:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I got my two 12" MTX's mounted like that on a plate. Face to face. It's called isobaric. Mine sounds great. Look at my pic in reader's rides. All I did was add a piece like this to cover that little cave on the back wall, so that air couldn't get through.
i _____________
/____________/
\_______/
I also added a strip on top, at the front so that the board would be firmly held down onto the sides of the well. Just cut it so it looks like this from the side. That way it flows the edge into the carpet. Then screw it to the car, not using any longer that 1 1/4" screws, if your using 3/4" board.
|\45 deg. angle
|_|
EDIT: Here's a link to the pic. https://www.thirdgen.org/rides/rideimages/Sub.jpg Hope this helps.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 19, 2001).]
Old Jun 19, 2001 | 09:23 PM
well thats not what I was thinking of but it looks good. I was thinking more of a bass tube(except square)...with the subs at either end. I was just wondering where I should mount the 2. Or more on how much room to leave between the subs...
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Zell1luk
Sep 29, 2015 10:36 AM
