What gauge wire should I use? Jim?
Old Sep 10, 2001 | 04:53 PM
DTGuitar's Avatar
I will be running a PPI 2600 at 600 Watts for the front stage and a Rockford Fosgate 800.2 at 800 watts for the 2 12" Subs. This comes out to 233.33 Amps of Current Draw... This is way off the only chart I have.
Will I be safe running 2 gauge to the back and then 4 gauge to each amp from a distribution block? Or do I have to use 1/0 wire from the battery?
All help is appreciated,
Dan
Daniel Galley
'88 IROC - SLP Exhaust
2 12" JL W3's.
Old Sep 10, 2001 | 06:54 PM
KlayBuRn's Avatar
i may be wrong, but my opinion would be 4 to distrobution then 8 to the amps...
MAYBE id run 4 to the Fosgate amp...jus keep all ground wires the same as power...
[This message has been edited by KlayBuRn (edited September 10, 2001).]
Old Sep 10, 2001 | 08:33 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Well, you'll never actually use 233 amps, because the sub amp will be the only major draw. 2AWG will not be sufficient. You'll need 0 gauge to a distribution, and if the run is short enough, 4AWG from the dist. block to the amps. Start with a 100 amp breaker, and if you keep popping it, step up to a 150.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 10, 2001 | 10:07 PM
DTGuitar's Avatar
The run from the Block should be at most 1.5 feet.. the amps are situated right behind the seats and so will the block. You suggest 2AWG from the block? I don't want to skimp it if it's close...
Also, do you guys know a place to get good wire (RCA, power, speaker)? Cheap, of course!
Daniel Galley
2 12" JL W3's.
Old Sep 10, 2001 | 11:15 PM
matthew's Avatar
<font face="Verdana, Arial" size="2">Originally posted by DTGuitar:
</font>
try www.partsexpress.com or www.mcmelectronics.com
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Sep 10, 2001 | 11:25 PM
matthew's Avatar
stupid double post
[This message has been edited by matthew (edited September 10, 2001).]
Old Sep 11, 2001 | 07:12 AM
Jim85IROC's Avatar
The biggest problem with the dist. block is that if it'll even accept 2AWG on the outputs, you're not going to be able to find a big enough fuse for the amp. I ran into this problem with my stuff. I've got 2AWG to my dist block, then had 4AWG from the dist block to my ZR600, but the biggest fuse I could find was an 80 amp, which I blew very quickly. I finally used 2 outputs from the dist. block and ran dual 8AWG wires to the amp, each with a 50 amp fuse. So far so good, but I'm planning to reposition everything so that the wire length is shorter.
The IROC Homepage
Old Sep 11, 2001 | 09:43 AM
FiReBReTHa's Avatar
guys... i think i might be screwed.....
i ran 2Gauge to 200Amp circuit breaker, then 2 to the distribution block, each with a 100 amp fuse to each amp, one amp, a jl audio 300/4 and the other a fosgate 800a2...
is this right or do i have to redo?
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
