Deck Dimmer
Old Sep 14, 2001 | 08:27 PM
Tyler-88's Avatar
Deck Dimmer
it just wont work. i got the option turned on and when i turn on my lights, the deck just wont dim. it used to work before, but nothing now, any ideas?
Old Sep 14, 2001 | 09:13 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
What color wire do you have it hooked up to? There's DIMMER, and then there's ILLUMINATION.... you actually want illumination, since THAT is what goes to +12v when the parking lights are on. I believe the dimmer varies in voltage, and NOT around the voltage needed to trigger the stereo's 'dimmer' function. It would also help to know what radio you're hooking up
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS
AOL IM Name: JimmyTime5
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Sep 15, 2001 | 01:58 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Mine works both ways on a Apline Deck.
All in the wiring and I'm not puling it back out!
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 15, 2001 | 09:35 AM
Tyler-88's Avatar
my deck is the pioneer premier 520, last years model. i think i got two options of wires, i'll check later today.
Old Sep 15, 2001 | 04:47 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Probably wrong wiring. The stock radio wiring lets you do this. Using a harness adapter really helps.
I think on Pioneer units you can only manually DISABLE the dimming option.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Sep 15, 2001 | 05:58 PM
Chris Luongo's Avatar
Oh, I know what it is.
On Pioneer and Premier decks, you have to switch the dimming feature on before it will work. Here's the procedure.
Turn your key to Accessory or Run.
With the Source button, turn the radio off. (Like I said, though, you have to leave the key on.)
Press and hold down the Function key.
When a menu pops up, you use the left and right arrows to go from one feature to another.
When the display says DIMMER OFF, press the up or down arrow to change it to DIMMER ON.
Also, the clock settings are in this menu.
Old Sep 15, 2001 | 06:18 PM
Tyler-88's Avatar
i know, the option is turned on. it worked before, but now it stoped, i'll play with it when it gets darker tonight
Old Sep 15, 2001 | 10:00 PM
Tyler-88's Avatar
ahh, piece of cake, the wire pulled out just as i suspected.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
