Head unit cutting out
Old Sep 18, 2001 | 01:34 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I recently bought the Sony ES CDX-M670. It worked great for about a week, and now its screwy. I for some reason or another i pushed the faceplate up while it was turned on. The unit just shut off!! It acted as if i had turned the unit off completely, not just "standby" I have gone over a couple of bumps (not big ones..CD doesn't skip) and it has shut off. Sometimes when i put the face plate on, it doesn't recognize it and stays FULLY off... its should goto "standby" mode when i put it back on!!! What in the world os going on? Is it a short or the unit... it worked fine!!! Its an awsome unit, i don't want to take it back.. i had a bad experience with the store, thats why i got a new head unit.. long story.
Help me!!
Old Sep 18, 2001 | 04:43 PM
silver89Rs's Avatar
check the switched power to the back of the radio mine did the same thing. the wires were pulling apart so i crimped them together
and have not had another problem
Old Sep 19, 2001 | 01:49 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Try cleaning the contacts on the back of the faceplate and on the deck with alcohol and a q-tip. They may be dirty. Also, look carefully to see if any of the contacts look bent or damaged.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Old Sep 19, 2001 | 10:29 PM
Omega's Avatar
Engine: LS1 / LS3
I took the head unit out and checked all the connections. I made sure that they were all secure and even taped up the antenna lead since it was exposed (i thought it might be grounding on something. All has been well excpept for one instance... the display blacked out. I pushed down on it and it fixed it. I think that the contacts are either faulty or dirty on the faceplate. I wouldn't think that they would be dirty though, its only been installed for a week!! Weird. I will clean the contacts though.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ZsTransAm
Aug 11, 2015 07:30 PM
