View Poll Results: Judge my plan then comment please i need the help
Good setup
28.57%
Proper setup (Adequate)
28.57%
Bad Setup
42.86%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Capacitor and Wireing
Old Mar 6, 2002 | 03:13 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
I'm up grading my power system
here's the deal
1 jBl 600watt mono
1 Clarion 440watt 4ch
Tell me if i'm wrong
i need:
1 cap (1 farad each) per amp, less than 12" in from amp
- questions
(1)
A 1 farad cap is good on up to........? watts amp
(2)
I Have 20 feet of 4 ga (+) Power cable
I Have 4 feet (-) 4 ga cable
I Have 20 feet (+) 8ga, 6 feet of (-) 8ga power cable
I Have 2way fused distribution block (1 4ga to 2 8Ga)(+)
I Have 2way solid Dist block (1 4ga to 2 8Ga) (-)
I Have Misc wires and relays for turn on circuit
All i need Right?
(3)
How do i charge the caps properly (light bulb in series with cap)
(i need steps)
(Optima yellow top and a 150 amp circuit breaker Good?)
Old Mar 6, 2002 | 06:07 PM
Car: 86 Z28
Axle/Gears: TBD
Yes I Did a search but i need specific info so if you are looking you should reply.
Old Mar 6, 2002 | 09:25 PM
TrueBlue91RS's Avatar
Two caps seems like a bit much to me, but I could be wrong. I'd test it out with one cap first and see if that's adequate.
If you're really worried about losing power during bass hits (usually the most power draining), then you could hook it up in line with the JBL alone. Your four channel will probably be alright. But if you set it up before the distribution block, you could use it store power for both.
Old Mar 6, 2002 | 09:36 PM
Car: 86 Z28
Axle/Gears: TBD
18 views 1 reply one vote and its mine come on people
Old Mar 7, 2002 | 12:58 AM
Torqomeo's Avatar
A single 1 farad cap should suffice for that setup. Generaly a 1 farad will handle up to 1000W I mean the more the merrier but the more the money also applies. I would cap the JBL for sure but the Clarion i would not worry about. I have used a 400.4 driving speakers and it never needed a cap. Cause you never really use it to its full extent. However i had a 500a2 and it would make the headlights dance to the music when a sub was wired to it. That amp would really pull the juice on any hard bass beat.
Old Mar 13, 2002 | 10:51 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
General theory is 1f for every 1000 watts. I'd place it within a few inches of the bass amp's power supply. It should come with a charging resistor. Hook the resistor in series with the power wire to charge it. Once it has been charged, put the resistor away in a safe place.
Old Mar 13, 2002 | 10:56 PM
Car: 86 Z28
Axle/Gears: TBD
thanks for the help
people
Old Mar 18, 2002 | 05:49 PM
Car: 86 Z28
Axle/Gears: TBD
Axe the jbl i just bought a rockford 360a2 for the sub. Whoo Hooo
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
