Look at this...full box or just this?
Old Nov 16, 2001 | 10:53 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
ok, my friend gave me this panel that holds 2 subs, and its jsut the panel, no box, its like the top of a box, it looks like this http://wsphotofews.excite.com/014/S1/pW/Qr/Gl84359.jpg but with just the top. Should I just stick to that or make a full box? I heard if I made the box it would raddle and shake all my glass in the back.
87 FireBird Formula
305 4bbl LG4
K&N Filter
Flowmaster 80 Series
Holley Quadra-Jet 650 CFM 4bbl Electronic Carburetor
P215/65R15 Tires
(2)Pioneer 6x9 Ts-A698
(1)Pioneer 8" Ts-WX75A Sub
Rampage 100 watt amp
-----Need Upgrades-----
--Give suggestions plz--
http://members.tripod.co.uk/michigan34/car.html
Old Nov 16, 2001 | 11:50 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by BuddyLeeX:
</font>
And this is bad why?
AJ
Old Nov 17, 2001 | 09:07 AM
DJSexay's Avatar
you may shake some of the plastic panels, but not the glass.
Also, what you have is known as a plate setup. It needs to use Free-Air woofers. Either way, most people agree that it sounds like crap, unless you can make a 100% seal with the well (remove carpet and actually silicone it to the metal).
I'd just make a box.
mike
custom 3rd gen kickpanels at
http://www.djsexay.com
Old Nov 17, 2001 | 12:07 PM
JucinGTA's Avatar
Hey the board SUCKS Ive had it, I also had the Box and I have bazooka tubes, I wouldnt even waste my time with just the board it wont seal right and it will sound like crap.
Old Nov 18, 2001 | 12:23 AM
BuddyLeeX's Avatar
hrmm...I installed my 2 12"s in just the panel running off of a 500 watt amp and it sounds really good...the board fits FLUSH into the back of the well, and there is no air gaps besides on the back cornors which the air comes out, but I still might have to port it. To me it sounds good for getting just 250 watts a piece.
87 FireBird Formula
305 4bbl LG4
K&N Filter
P215/65R15 Tires
MTX Thunder6000's 12" subs
Jensen KA3 500 Watt Amp
Old Nov 18, 2001 | 02:52 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
Buddy,
I don't want to bust your bubble, but crank your system and put a lighter anywhere near the edges of your board. I'll bet you'll get a nice flow of air coming out. It might sound good to you, but its not the best way to go. Porting it might make things alot worse (especially if you just plan to cut a hole and put a port in ***** nilly without any math to go with it)
The good news is that you can measure, and make a box and still have that board to listen to in the mean time. So you can still run tunes until you have time to do it right.
Juan
Old Nov 18, 2001 | 08:48 PM
BuddyLeeX's Avatar
That soudns good, I think Im going to make a box to complete the top anyway because Ive heard that it woudl hit better if I did make it a box. Also I am thinking of rounding out my 2 12"s on my box by putting in a 10" MTX in the middle, and also by getting me a 1000 watt amp cause my amp right now is just putting out 1/5 the power my subs can handle.
87 FireBird Formula
305 4bbl LG4
K&N Filter
P215/65R15 Tires
Clarion ProAudio DB315 Deck
Pioneer 6x9s Ts-A698
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
