HELP!! NO THUMP!
Old Dec 13, 2001 | 07:23 AM
MoDiPhYd's Avatar
HELP!! NO THUMP!
I need your help, I put in a stereo system with my friend the other day. With 2 12"s in the hatch. In his car (he had a trunk) they thumped damn good! In my car they barely thump. How do I get them to work right? We were thinking seal them inside the well, so its enclosed? I need some input........
Old Dec 13, 2001 | 09:15 AM
85IROC-C's Avatar
Did you use the same amplifier? What about the enclosure: same one? Ported or sealed? We'll need to know more before we can answer!
I'm guessing it's amplifier power, but if the subs were in a ported box in a trunk, you'll get the "cabin effect" causing some horrendous thump. The same box in a hatch would not benefit as much from the ported arrangement, but the difference shouldn't be so noticeable as to warrant a post here!
Old Dec 13, 2001 | 09:17 AM
VampireHunterC's Avatar
Are the subs in a box, or free-air? If they are in a box, and the box is sealed, then they should thump, as long as you are running enough power to them. If they are free-air, then you have to run a signifigantly larger amount of power to the subs in order to make them thump.
Old Dec 13, 2001 | 09:20 AM
jobryan26's Avatar
Was you using a Plate in your car and not a Box?
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Dec 13, 2001 | 09:59 AM
MoDiPhYd's Avatar
I have a hatch box and it had sub ports but I put wood over them to seal the box. I have them facing down (towards my gas tank) in the well. How can I get more THUMP? it sounds like **** ;(
Old Dec 13, 2001 | 10:01 AM
MoDiPhYd's Avatar
Oh yeah.. I have an amp too.... I have both subs running through the same channel. They're bridged I guess..
Old Dec 13, 2001 | 11:29 AM
DJSexay's Avatar
you can't just cover the ports on a ported box to make it sealed. Ported boxes are typically bigger than a sealed. What kind of subs are they ? How much airspace is recommended for them. Remember, install is everything.
mike
custom 3rd gen kickpanels at
http://www.djsexay.com
Old Dec 13, 2001 | 12:13 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Please don't take critisizm from this, but do you have the wires running the right way?
Sometimes if you accidently hook up one of the speakers wrong (+ wire to - terminal & vise versa) then they'll be running outta phase. IE, cancelling each other out.
After years of doing this, about the 3rd time I did that, I finally learned the 'measure twice-cut once' rule.
AJ
Old Dec 13, 2001 | 02:11 PM
deadtrend1's Avatar
thats just what i was about to type. Being outta phase would make you hear the bass but not feel it
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
Old Dec 13, 2001 | 06:14 PM
MoDiPhYd's Avatar
I took the subs out of the box and I am putting them in my well, then I am going to put wood over the top of the well so its flush with the rest of the hatch... Thus, resulting in thump
db057
Aug 22, 2015 08:17 PM
breathment
Oct 27, 2003 09:52 AM
breathment
Mar 29, 2002 07:07 PM
Eightyninef
Oct 4, 2001 09:28 AM
breathment
Sep 23, 2001 04:42 AM
