Would this work ok?
Old Mar 18, 2002 | 10:15 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Would this work ok?
I just finished installing my MTX subs and amp today in my 92 'maro. The wiring kit that I had bought supposedly had an o type terminal to hook up to the battery side posts. Well, it would not go on with that. I looked at a bunch of connectors I have lying around from past projects, and couldn't find anything that would mount on the battery without problems. I ended up mounting the amp power cable to a distribution block that comes next to the battery from factory. Will this be a problem? It works, but I would think that the subs are not gonna work up to its potential, and that I am compromising the power on all the other components. What did you guys use to hookup your power cable?
Old Mar 18, 2002 | 10:55 PM
deadtrend1's Avatar
I would just buy extended battery terminals. I ran a power wire to the input terminal on my celenoid on my pickup and beleived it would lead to potential danger.
Old Mar 21, 2002 | 09:15 AM
coalyard's Avatar
Lots of companies like Monster Cable make accessories such as battery posts for this application. This is the route to go. You spent a lot of money, time and effort on your system, why jerry rig it and risk problems down the road? Yeah, they are a bit expensive, but in the end it pays off with not having to worry about it. Never compromise the vehicle itself to install aftermarket stereo equipment. After all, you bought a car to drive it, not to be a listening room ;-)
Seriously though, amps need a good steady power supply directly from the battery, and a solid ground to the chassis to work trouble free.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
