wire for power antenna is which ?
Old Apr 8, 2002 | 10:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the small pink wire ? i put tape deck am.fm reciever from 84 firebird into the 84 Z28 and it does not pick up any stations, its completely dead air, just static, and antenna does not come up, all there was on back of reciever to plug the pink wire on car into was a gray one, but i dunno if thats meant for power antenna or if the pink wire in car harness is even antenna
ideas ?
thanks for anything
Old Apr 8, 2002 | 11:26 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Are you sure you have a power antenna?
I see you just purchased this car, so I was just wondering.
Old Apr 9, 2002 | 12:01 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ive been all over the car, all through the RPO codes all through under neath the car al through under the hood making the car how i want it, the antenna is inside the fender and it wont come out, no it does not hahve integral windshield antenna and no it has no fixed mast antenna, the firebird does have fixed mast though
how do i make it come out ? which wire is it ?
thanks
Old Apr 9, 2002 | 12:27 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Well I think its the Pink/white stripe wire, but not sure.
All I can say is look through the fender to where the antenna is, and see what color the wire is. Spray it down or whatever you have to do to see what color it is.
Then put it on the remote wire (if your radio has it) or on the ign. wire. The only problem with putting it on the ign. wire is that when the radio is off the antenna will still stay up. But when you turn the car off it will go down. Its up to you.
Old Apr 9, 2002 | 12:54 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
doesnt matter to me, i would be happy if it stayed up, i dont care, just as long as it works, although I am unsure how they work,
how do they work anyways ? does it take a charge of power to make it extend and another to make it descend ? or constant
power to keep it extended ?
thanks! i wil tackle this tomorrow if is not raining stil....
Old Apr 9, 2002 | 01:07 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
You got me on that one.
I have an Idea, but I'm not going to confuse you.
Or I just dont want to embarass myself, if I was wrong.
Old Apr 9, 2002 | 01:11 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hehe, i hope that wire is pink in that fender! if not then hmm i may just be swapping power for fixed mast.. IE ol' reliable style
thanks
Old Apr 9, 2002 | 02:52 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Hey man, did you try to take the panel off under the dash in the passenger side foot well? You should see the black antenna wire, and maybe, just maybe, the power antenna wire will be with it.
There should be a whole mess of wires under there, most for the ECM, but you could get lucky.
Old Apr 9, 2002 | 09:04 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeah, youre right, I may get lucky there under the panel,. hmmm i never got to mess with it today, i did start clenaing out and selaing the roff body to t tops weatherstripping channels vallies on the car today though, used black rtv on pass side and ran out cuz i thought one tube would be enough, but wasnt, so i had to use tub and tile caulk on drivers side... I used masking tape to keep the stuff off the paint, so far so good, next is to seal the hatch hinges and finsish selaing in the center rear of the T bar where both tops openings come together, big gaps there...
then wait for rain and pray.. wa slots of rust and wet still in the tops stripping seals channels where body panels pinch weld around the openings, thats not a good thing, rust rust rust...
i hear silicone is bad for metal in that it traps moisture inderneath and causes rust too... but what else can be done,,,, there is another thread regarding hatch hinges and some type of GM brush on type of sealer, i need ot find that thread and get some of the stuff tommorrow, maybe somone reading this knows off hand wehat its called ?
thanks
Old Apr 9, 2002 | 10:54 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I know how you feel on sealing the T-Tops. I sealed and sealed, and to tell you the truth they still leak every now and then. I found in my trials that most of the water comes from the spot where the black T-Bar meets the body. Make sure that spot is sealed up. There is a tech article on this if you need more info.
As far as silicone being bad for anything, I have never had a bad experience with it. Silicone keeps water out, not in. Now somebody will try to give some scientific explanation, but I'm not buying it. But, you should have went and got some more RTV, it just might look tacky with two different colors. Dont worry, the silicone comes off really easy (if you want to take it off), just rub it with your finger really fast and it will come off. That didnt sound good.
Old Apr 9, 2002 | 11:09 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i did a really super neato job of doing this, i separated the seals from the roof body and cleaned it all out real well and then laid in the sealer, cant really see uch of it its all down in underneath the stripping, il go over the top of the white on drivers side with black when i et more tommorrow so i can finish up the t bar ends
shoudl help alot, wont know til thursday and days after- when rain is gonna be here again
Old Apr 9, 2002 | 11:16 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Oh BTW, why do you think the hatch hinges are leaking? Just wondering. I mean, do you know for sure the Hinges are leaking?
It is usually from the T-Tops leaking, which drips down the sail panels into the backseat.
Old Apr 9, 2002 | 11:27 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
there was a post all about the hatch hinges, i guess you missed that one, a TSB on it too
Old Apr 9, 2002 | 11:34 PM
White Ninja's Avatar
i've have problems with the hatch, too. i'm still in high school and Monday of this week, after spring break, i went to get my notebook out of the spare tire well and the thing is warped.. like it was sitting in a puddly of water for a week........ nothing else seemed damaged though?????? I also have leaks in the t-tops, on the inside... my car has every option, so it has all the finer-roll meters like "service/celebration/etc" you know what i mean? anyway, it was raining one day, i get in my car, and look at where the power window buttons are and there's a big F'off puddle there!! i look up and the roll meters had drips on them.
Old Apr 9, 2002 | 11:37 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
LOL, yeah mine stay on the Celebration/Trip settings.
Who knows when they worked last, probably when the Computer was taken out.
They just remind me I need to party soon.
Old Apr 9, 2002 | 11:55 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
been longgggggg time sinc ei last was at a party, hard ot get away with throwing a party here unfortunately, i know a girl down in paris TX, too bad im not down there...
hatch hinges thread: https://www.thirdgen.org/techbb2/sho...threadid=93305
Old Apr 10, 2002 | 12:04 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Who's the girl you know? I might know her, probably not.
I've only lived here for a year so... Just moved here from Dallas, sux up here. Theres a drag strip 2 mins. from here so thats a plus.
Thanx for the link.
Old Apr 10, 2002 | 12:18 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
last name is lane, so if you know any with the last name then you may know her, i dunno,
drag strip!? wow now that could be neato! wonder what those are like
anyone here happen to be affiliated with Ron Laney Oil Co. (Exxon) in Seyhmour TX ? i got a 71 C-10 recently that was their company truck, phoine number on the doors of the truck is stil good, apparently the Co exists still.
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
stalkier
Aug 13, 2015 12:59 PM
