Performer RPM Air Gap Manifold...
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Anyone have one? Is it at all possiable to use under the stock hood? I'm building a new engine and that's the manifold I want, do I have to go to a cowl induction hood??
Car: 1983 Z28
Engine: 6.6L 406
it is real tight with the regular RPM and a drop-base air cleaner. The Air-gap is like a 1/2 inch taller.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
It will fit, depending on what carb you go with. It fit under mine with the Edelbrock 750 with a Moroso drop base air cleaner and a little hood adjustment. I ended up having to go with a holley 700 DP and I had to get a spacer to get the secondaries accelerator pump arm off the intake, so that caused hood clearance problems. It's better off to go ahead and get a cowl hood.
87'IROC-Z 357
440 hp carb'ed monster
(barks much worse than its bite)thanks to edelbrock
87'IROC-Z 357
Dialed_In
Aug 20, 2015 01:45 PM
