Rochester Q jet on a 350
Old Jul 9, 2001 | 04:50 PM
icenine9's Avatar
I want to take my Q Jet off my 305 and put it on the 350 i am rebuilding, will the carb provide enough cfm, if not can i tune it so it will?
Old Jul 9, 2001 | 08:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon the mood at GM when your carb was built. The answer to your first question is "maybe", and the answer to the second is "yes". Check out the tech articles.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 12, 2001 | 05:06 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
All Q-Jet carbs are rated at 750cfm or higher. They are controlled down by the fuel circuitry. If the Q-Jet in question is not CC, then you should not have a problem getting the 350 to run with that carb, but you may need to change metering rods, or the jets to get it to run well.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Old Jul 14, 2001 | 10:05 AM
five7kid's Avatar
Not exactly. All may be CAPABLE of flowing 750, but as many 3rd gen owners know, LG4's often have the secondary AV stopped less than full open. ice, you didn't say what version of 305 you have, but L69's typically had carbs that would allow full opening, LG4's did not. Mine happens to open fully, and some people have indicated when they picked up a rebuilt carb, it also would open fully when the core they turned in would not. That is why I suggested checking out the tech articles to see if ice needs to do any modifications to feed that 350 properly.
Tuning for a 350 is practically a given. Modifying for full CFM flow is not. Nor should the assumption be made that modification for full flow is not needed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
