my stock carb
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my stock carb
i have 2 questions
first off
how many cfm is my stock carb for my 84 ta L69 305......
and my second one is...what would b better to do....make my stock carb hi-po or just buy a holly 650cfm or something of that sort
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
first off
Car: 84 T/A
Engine: 305HOL69
Are you going to be using the car more as a daily driver, or more for racing exclusively?
Reason I ask, the Q-Jet can flow 750cfm. Stock/original, they're around 600-650ish. Kept up properly, they'll get you great street performance and decent mileage and they're moddable to flow 750. That's what I use on my car, and i've got the same car as you. The last time I ran the car (G-Tech, anyway) it pulled off a 14.4@93mph with the CC Q-Jet, but i've got additional mods to boot.
If you really want to get into more drag performance and put a different non-CC carb on there, you'll also be looking at a vac. advance distributor, and a Torque Converter lockup switch or kit. Basically, when the Q-Jet is removed, the Electronic Spark Advance and Torque Conv. Lockup will quit working for lack of the Throttle Position Sensor.
Hope i've helped some.
[This message has been edited by eightTfourTA (edited July 21, 2001).]
Car: 1984 Trans Am
Engine: Vortec 355
oh really
thanks
yah im already need my carb to b worked on cuz when i floor it sometimes it just bogs down until i let off some and then it accelerates again
what did you do to your carb....i read a post where the guy filed down the air valve stop...installed "DR" rods....installed a "G" hanger....Reduced the tension on the secondary air valve tension spring from it's stock setting of 1 full turn to about 1/2 turn.....is that all you did or did you do more stuff
and thanks for the help
thanks
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
[what did you do to your carb....i read a post where the guy filed down the air valve stop...installed "DR" rods....installed a "G" hanger....Reduced the tension on the secondary air valve tension spring from it's stock setting of 1 full turn to about 1/2 turn.....is that all you did or did you do more stuff
That is exactly what you want to do! Also, buys some carb cleaner and spray everything clean, then spray the remainder down the secondaries. Also, put some in the gas tank.
1986 Camaro Sports Coupe
T-tops, power hatch, rear defrost, third brake light
LG4 305 V8, "Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, pw, pl, pb, ps, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
Car: 1984 Trans Am
Engine: Vortec 355
alright thanks a lot!!
well i better get a rebuild book for my carb if im gonna do this myself
do any of you know where i would b able to find one....i went to barnes and noble and i dont think they had one
I have just rebuilt my Q-JET on my L69. In addition to the great tech articles here, I found a good website good website that has alot of information about the Q-JET. It even has a full parts diagram, which was valuable to be since I did not know what everything was called at first.
Check out: http://www.montecarloss.com/technical.html
Look about 3/4 the way down the page, under "Air Fuel Induction"
Hope this helps
Hope this helps
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
