How Much Would A Shop Charge to Tune My Carb???
Old Jul 25, 2001 | 09:48 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
OK, I am 200 miles away from home right now and will be leaving in 2 days. My car has started to run rough (sputters when I accelerate) and I know my carb needs tuning anyways. Where I am at right now shops don't charge alot for service, I was wondering what they might charge to tune my carb. possibly changing rods and jets.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 25, 2001 | 10:31 AM
V6camaroman's Avatar
around $30 to $60 for a good rebuild
Old Jul 25, 2001 | 10:56 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by V6camaroman:
around $30 to $60 for a good rebuild</font>
This is what they might charge if nothing needs rebuilt.
It depends on exaclty what needs to be done. Just an adjustment anywhere from 0-30$ that means just turn some screws over. there sno way someone could justify more than a .5 for this. Now If you carn needs rebuilt 50$ for the kit and 1.5 for the rebuild.
My friend payed a shop 200$ to have them tune his edelbrock I would have told them where to stick it, but it did include jet/rod change so ehh. Of course I could have done it for free.
SSC
Old Jul 25, 2001 | 11:34 AM
Car: 99 Formula
Axle/Gears: 342
Well I replace the fuel filter and sprayed carb cleaner. It seems to have helped a little, I think I am just going to try and make it home and have someone look at there that doesn't charge much.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Jul 25, 2001 | 05:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
IIRC edelcrock carbs don't have a PV in 'em. Everything is pure mechanical or airflow sesnitive. Thus, the odds that a carb problem is causing you to run rough all of a sudden doens't seem likely, unless something broke or got a serious boogie in it (possible, but just not likely)
I'd check all the basics and be looking for either shot tune up parts or something in the distributor that isn't right.
...ed
Old Jul 26, 2001 | 02:53 AM
DualCarb's Avatar
I believe it would definitly be under $100 for a rebuild lower for lower end places but the maximum should not be over 100.
1986 Iroc z28
4bbl 350 V8 430 hp
300 shot NOS
6 spd Manual
20" Iroc replica Rims
2, 12" Alpine Subs
4.11 gear ratio
1/4 mile - 10.52s and 10.86s
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
