Converting from carb to Multi-port?
Old Jul 25, 2001 | 08:34 PM
bklucas12's Avatar
Pretty new to the scene dont know much about cars, but I just wanna throw this at you guys and see what you think, prolly wont happen but just wanna see what you think.. I have a formula with a performance edelbrock carb, it was TBI but for some reason the owner before me decided to put an edlebrock I think 750 cm carb on, performs REAL nice but, but I was thinking of buying a MPI, muti-port fuel injector kit from edelbrock, HAHA only 2000 bucks HAHA, what do you guys think, would it be worth the money?
Old Jul 26, 2001 | 01:19 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
You can get much better fuel injection for under 2000 bucks and have money left over for other go-fast or look-good parts. If you're serious about going fuel injected, look into buying a used TBI or TPI system (in fact, I've got a TPI system I'd be willing to sell at the right price). You can usually get them for a fourth of the price if you shop around. It's really hard to beat carb for cost efficiency and pure, raw power. I would only switch to a fuel injected system if you wanted more fuel efficiency, although it is possible to tune a carb to meet or beat a fuel injected system as far a milage and drivability. It's much easier to turn a couple of screws or change jets than to spend days or weeks burning the right chip.
Old Jul 26, 2001 | 07:29 AM
bklucas12's Avatar
Thanks, but I think Ill prolly keep my carb, like you said it does have its advantages over fuel inection, and I dont care about fuel effecientcy just about raw power, I would take 1 MPG if it ment I would get 600 HP, anyways my car had TBI and for some reason the previous owner put an AWESOME looking edelbrock performance carb, I dont know to much about cars but the guy told me he had tuned the carb for performance, so I guess my car has a bad *** edelbrock and Im fine with that, thanks for the help though.
Old Jul 29, 2001 | 08:32 AM
86IrocZ383's Avatar
If you want raw power put a tpi on there and you will not regret it. I went to the track and ran a 12.47. I lost 4 tenths after I took off my 750 Holley and put a stock ported TPI on there. It is 100% better on gas and has alot more low end power. With the holley it would burn out for 75 feet and with the tpi I can lay rubber from a dead stop for over 300 now. I'm telling you if you want raw power put a TPI setup on there and you will like it.
86 Iroc, 383 Ported and polished Sportsman II, stock ported TPI, #24 svo, custom chip, Slp 1 3/4, Comp Cams roller 218 224, 10" 2600 stall, Fairbanks 700r-4 W/superflow pro pump, 12.969@106.54 1.991 60', new times in spring
87 K30 Chevy P/U 355 TPI Crane Compucam, Ported heads TH400, Hooker headers and edelbrock mufflers (LOUD)no cats, 8" lift, 36" super swampers, 4.10 detroit lockers,
Old Jul 29, 2001 | 09:22 AM
bklucas12's Avatar
TPI units cost a crap load, if you know where I can get a NEW TPI unit for my formula at a cheap price I would more than appreciative, but I dont have the money to get that right now, I just bought a cat-back headers and need some body work done..
Old Jul 29, 2001 | 11:18 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I know plenty about cars and I am getting pretty good under the hood, I can only say good things for carbs. If you ever do start to really work on your car you will be so happy you stuck with a carb. They are much easier to work on, and you can usually tell whats wrong straight off. The computer is nothing but trouble...
1984 Firebird - Daily driver
305 LG4, T5 - Hurst Short Shifter
Edelbrock 600 CFM Performer Carb - 14X3 K&N Open Element Drop Air Filter
Gutted Cat... gonna need a cat-back for next year
IROC 16x8 Wheels
Goodyear P215/60/R16
AIWA Bargain Basement (from Sears of course) CD Player
Quote from my sister:
"It sounds like a boat"
Special Features:
Non-functioning parking break
Non-functioning rear hatch pistons
Broken heater ****
Disconnected engine computer that continually says check engine
Future plans:
New Paint - take out two small rust holes
Reupholster the ceiling (bare foam now)
Highflow Cat-back exhaust
Dual 12" Subwoofers, real speakers in place of OEM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
