What does the Performer RPM intake do for me?
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Ok, I have a performer RPM intake on my LG4 coupled to an Edelbrock 1406 Carb, so what exactly does this do for me over the stock setup power wise? Do I get more Hp, Torque or both? How much of a gain is it?
My other question: Does the performer intake bolt straight up to Q-Jets?
Thanks in advance.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb + Intake - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, AIWA bargain basement (from Sears of course) CD player, Eight-ball shift ****
Check out my ride here - My $1300 Toy
Thanks in advance.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I think for your engine an edelbrock performer and not the performer rpm would be better. But if your future plans include more mods (or a modded 350)I would stick to an rpm instead of the performer. If I am correct on this I think the perfomer rpm would need an adapter for a Q-jet.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I actually just think it's a plain performer intake... The previous owner made several modifications to the car and some of them he didn't tell me about... how could I tell if it's performer or RPM?
What benefit does it have for an otherwise unaltered engine?
Also, there are four other bolt locations which would lead me to think it can handle a q-jet... Anybody else know more about these intakes?
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Ok, sounds like a good test... I have 2" clearance w/3 inches of pro-flo air filter.
So what is the benefit? Does it add Hp or just help other mods make more Hp?
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by ChillPhatCat:
Ok, so I've got a performer... now what does it do for me? I'm running a pretty much stock LG4</font>
SSC
[This message has been edited by SSC (edited September 26, 2001).]
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
So, it all depends on the flow that I plan to pass through it? If I had an engine that wanted more air then it would fulfill the needs better? In other words, further mods will not be limited as much as the original manifold? Since I am slowly finding mods hidden here and there, would it be reasonable to think that the previous owner might have done some internal work?
I still need to get this car to the track, at least put it on the dyno... cause this car feels kinda fast for an LG4... I'm interested to see, but I won't get my hopes up...
Car: 1989 C4
Axle/Gears: 307
So, it all depends on the flow that I plan to pass through it? If I had an engine that wanted more air then it would fulfill the needs better?</font>
The aftermarket "stock replacment" manifold basicly allows you to have a better choise of carbs. If you want more power from what you have I would suggest that you invest in porting your heads and geting headders. The performer does flow more than stock but if that air cannot have a clear path to the comustion chamber it does no good. Your next step would be to get headders so the exhaust gases can be explled better, a more "free flowing" system all around. If the previous owner did mod the car he/she most likely changed the cam to a bigger one and with exhuast, intake and heads flowing freely the cam can reach its potential and all the bolt on parts actualy do something besides look cool
It's a give, give, give and then gain process, anyone who thinks they can bolt somthing on and gain major HP is a fool.
"A typical ***** comes to mind"
I admit I was a fool before and thats where I learned from
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"Web site under construction"
G0D Bless.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
So here I am and I've never seen a dynomometer... Is this a hand held device? Are they cheap enough to own? Where can I go to get it dyno'd? Is this something most auto places would own/perform?
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
<font face="Verdana, Arial" size="2">Originally posted by SSC:
</font>
</font>
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I bet if I bolted on a jet engine I'd se a big improvement in my 1/4...</font>
Car: 86 z28
Another thing a performer (which is aluminum)gives you or takes away from you is weight.
An aftermarket intake is the way to go if you plan on modding your engine. Also if you plan on going with a 350 in the future you might want to get parts that will benifit that 350 later one.
An aftermarket intake is the way to go if you plan on modding your engine. Also if you plan on going with a 350 in the future you might want to get parts that will benifit that 350 later one. Thread Starter
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I'm thinking blown 400 for my next engine
Right now I'm trying to break the 200 Hp mark, but I think I want about 500 Hp in the next engine (or car).
Right now I'm trying to break the 200 Hp mark, but I think I want about 500 Hp in the next engine (or car). Thread
theshackle
Sep 17, 2020 08:26 AM
